914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,266 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
What do you guys think about doing your own alignments? There's real cheap tools for setting camber or you could set up something that uses a tilt box. Toe in is easy to make a fixture to do that. I'm asking because I have 4 cars that will need alignment soon and I do at least 1-3 cars a year. The shops are all 60+ minute round trips, up to a couple hours there minimum, so by time I get back a better part of the day is shot. I do my own. As far as I can tell from having paid for it before, there is no difference except a lighter wallet. |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,209 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Yep, I was thinking about that because my floor isn't perfect. My idea on that is bolt plates to the floor in the four corners that are perfectly level. (IMG:style_emoticons/default/idea.gif) Linoleum tiles. (Or other thin-ish floor tiles.) Use a nice tube level (tube with colored water in it) to figure out how much height has to be added to the floor in each spot. You can even paint the number of tiles on the spot on the floor so you don't have to measure every time. The tiles are tough and stack to give you a decent amount of leveling. Put driver-equivalent weight in the driver's seat. Especially if you're a big guy like many of us. Strings are a little bit of a pain to set up--mostly getting the reference to the actual centerline correct--but are dead-nuts simple once they are set. If you're going to be aligning one car a whole lot, it can be worth it to build fixtures that attach to the car itself that hold the strings. Still useful, but less guaranteed to be precise, on other cars of that model. Measuring camber is easy. Caster is the tough one, and usually you'd just measure camber change as the steering wheel is turned a specific amount. --DD |
larryM |
emoze ![]() ![]() ![]() Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California ![]() ![]() |
For me the cars have always been driven on the street but only a limited number of miles each year. The tires are going to get too old long before they get worn out from excessive camber. I say go for the most performance you can w/o burning through tires before they they are too old and need to be replaced due to age. 'yup - $$$$ long time ago, my six was setup by Ken Mack of Sportech in Sunnvale for "combo use" - vintage racing, AX & street - for racing i ran 7&8's with directional tires (Ken was an accomplished 914/6 racer, so he knew what would work) front camber -1.5, caster 5*, toe =00; rear -2.0 camber, rear toe 0.4' it's incredibly stable & neutral on the track (of course i have a full competition suspension & am running 8x16" wheels & spacers with about 1-1/2" more track width to go with that claim, so ymmv) yes - it eats tires; - i made the mistake of buying g-force summer performance street tires a few yrs ago - they were stone hard in 4 yrs with under 30% wear - scary on the street & really awful at AX - and cuz they were directional I had to pay to have 'em swapped side to side on the wheels to compensate for the camber wear (worst on rear) for that reason i now run 4 Fuchs 7x16's all around with AS3s, so i can cross-rotate to improve the life a bit; and they are still competent enuf for occasional AX & DE track use maybe someday i might realign it to less drastic specs, ( i saved a boxful of rear plates for just that reason) but as said above, our tires will be age-dead long before camber wear is a problem - i have the string setup & Smartcamber tools as well as a set of snap-on turnplates & Ammco gauge & Ray Scruggs book, & have done several of my cars that way, - as others say - if we value our time, just pay to get it done - either way "a day is shot", and we might additionally get some good advice from a tech who actually races or AX's & knows what the settings affect ( yes, i live 60-100 miles from any competent race-align shop that knows Porsche's or has an interest in the extra time cost of doing a to-my-spec-job) (... pay attention to DD - he has been competently answering this question for as many yrs as our forums & old BBS's exist) (IMG:style_emoticons/default/wacko.gif) |
I think you meant front toe-out to improve turn-in. Rear toe-out gives you a car where the back wants to steer the front...
--DD |
jmitro |
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None ![]() ![]() |
I think you meant front toe-out to improve turn-in. Rear toe-out gives you a car where the back wants to steer the front... --DD (IMG:style_emoticons/default/agree.gif) |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Yep, I was thinking about that because my floor isn't perfect. My idea on that is bolt plates to the floor in the four corners that are perfectly level. (IMG:style_emoticons/default/idea.gif) Linoleum tiles. (Or other thin-ish floor tiles.) Use a nice tube level (tube with colored water in it) to figure out how much height has to be added to the floor in each spot. You can even paint the number of tiles on the spot on the floor so you don't have to measure every time. The tiles are tough and stack to give you a decent amount of leveling. Put driver-equivalent weight in the driver's seat. Especially if you're a big guy like many of us. Strings are a little bit of a pain to set up--mostly getting the reference to the actual centerline correct--but are dead-nuts simple once they are set. If you're going to be aligning one car a whole lot, it can be worth it to build fixtures that attach to the car itself that hold the strings. Still useful, but less guaranteed to be precise, on other cars of that model. Measuring camber is easy. Caster is the tough one, and usually you'd just measure camber change as the steering wheel is turned a specific amount. --DD Thanks Dave I've found a few sites and YT vids on how to do this. Since I may be doing this often enough I'm going to look into a more permanent level floor area solution. I'm also thinking on making corner balance fixtures, found a niffty calc program for using 4:1 fixtures and bathroom scales. http://rennlight.com/cgi-bin/balance.cgi?n...p;LR=0&RR=0 |
I have heard from folks on the Bird Board that the bathroom scale solution does not work very well. It is sensitive to exactly how you set it up, and difficult to get repeatable measurements.
I didn't check the link, so it is possible that this is a better version than discussed on the Bird's Racing BBS, and doesn't have those issues, but it's definitely something to at least think about. --DD |
HalfMoon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region ![]() |
I've recently found a Porsche shop here in the Eastern Panhandle of WV that can do four wheel alignment and corner balancing and I've finally finished with most of my suspension and brake work (must replace atrocious spacers near future), so I'm wondering what recipe's the go fast crowd might suggest? Dave and Chris, please chim in! The stats: V-8 Hankook Ventus V12 evo 225/50ZR16 front, 2.5” spacers (atrocious I know, thanks PO) Koni red front Stock sway bar front Turbo tie rods Fuzion ZRi 245/45R16 rear, 3” spacers (nutz, thanks PO) Koni yellow with perches 220 springs Stock sway bar rear Boxed trailing arms Rear chassis stiffening kit. 1986 911SC front hubs Primarily street with no need for tire longevity, sometime track day car Summit Point WV Additional info-Sheridan standard widebody. Quite a bit lighter than stock. Soooo, this is what Performance Automotive in Kearneysville, WV (just down the street from Summit Point Raceway) suggested. Camber , Toe-in , Castor Front L, -.94 , All 1/16 , 5 1/4 Front R, -.65 Rear L, -1.64 Rear R, -1.54 Corner weight- Front 490 both Rear 700 both Stock Curb weight 2138 Mine (sbc) weight 2380 Keep in mind this isn't an exact science and when you take some here, you have to add some there, gain here, compromise there. Each car is unique. This was as good as they could get what they were shooting for without ALOT more modification in suspension adjustability. Initial test drive seems like a different car. I can corner in excess of my ability. Track day tomorrow at the Point to see more and learn, learn, learn! |
Mark Henry |
I have heard from folks on the Bird Board that the bathroom scale solution does not work very well. It is sensitive to exactly how you set it up, and difficult to get repeatable measurements. I didn't check the link, so it is possible that this is a better version than discussed on the Bird's Racing BBS, and doesn't have those issues, but it's definitely something to at least think about. --DD Good to know when I get that far I'll post my results. The link is just a calculator for 4:1 set-up. As if I need another project on the list (IMG:style_emoticons/default/unsure.gif) The guy was using Ruggles scales which look fairly simple to copy. (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-26-1498771731.1.jpg) |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
There's someone selling a real set of corner weight scales for $500 on pelican.
larryM |
a chart in Porsche's 1972 Info for Sports Purposes suggests the following for a 914-6 camber front -20' to 30' camber rear -30' to 40' toe in front 0 +/- 10' toe in rear 0 +/- 10' castor 6* to 7* that is with 185/70x15's on 7" wheels here's some notes from several old threads: 914 alignment 4ncarGuy: Alignment shims 914. . U can't align the 914 with out rear alignment shims this is what changes the rear toe and camber & caster. ( one millimeter changes the camber 10 minutes or 10 degrees) DD - Stock specs are for 0 camber front, -1/2 degree rear. I like to push those to -1.0/-1.5 (F/R) for an aggressively-driven street 914. More than that is getting into the realm of "racing" alignment Suggestions for a somewhat aggressive street alignment: Front camber, -1.0 degrees. Front toe, 1/16" in. Front caster, 6 degrees. Rear camber, -1.5 degrees. Rear toe, 1/16" in. For a less aggressive street alignment, back off the negative camber F&R by about 1/2 degree. This assumes a relatively neutral balance in the choice of suspension components. Different suspension setups will "want" different alignment specs. (E.g., those with bigger front sway bars may want more negative camber up front, or less in the back.) I have found the above setup to work pretty well with stock suspension components, hard-compound tires, and rather aggressive driving (including some autoX). REAR: Remove shims for more negative camber. Add them for more positive camber. The shims go above the outboard suspension pivot point, and below the chassis. So making the shims thicker moves the outer point down, tilting the top of the wheel outward. That's (in the direction of) positive camber. ( one millimeter changes the camber 10 minutes or 10 degrees) Brad Roberts- I like to run 1.2 neg front and 1.5 neg. rear with 5.5 caster in front and 1/16 of toe in front and rear. this is ok for street tires (just barely) you will see uneven wear over time. for falkens.. 1.5 front and rear with the same caster and toe. Most 914's cant get 1.5 neg in the front without modifying the tub. John rogers 07-08-2002, Stock alignment works okay on the rear and same for front with an increase of negative camber to a full 1 degree on each front wheel. track cars car run with 0 toe-in front or even some toe-out but that makes the car really jumpy on the street. Make sure all mods to the suspension have been done such as lowering, shocks, springs, sway bar, etc before the alignmnet gets done. There are several posts concerning what alignment specs to use and they differ slightly between street and the track. They are on this site and the other two 914 web sites too. Usually for street use you want slight negative camber and slight toe in, in front, while for racing more neg camber and some toe OUT in front is better. If you are just going to drive a little you could get the home alignment article from the site here and then do a professional alignment after all the parts are in and everything has been finalized. That can also include a good corner balance which will make things really handle better. Wayne has just posted an article on home checking alignment on a 914 I wrote and some picts to go with it (what's new). Can one or two of the math wizes out there (DD?, Jeff?) check my math I used with the Law of Sines? The numbers in the article are based on 15 inch wheels only, any other size would be in error. I have had a couple of checks already, but more never hurts. Dave at Pelican Parts 07-08-2002, Max front caster, but keep L & R equal. ~1/16" toe-in at the rear, 0 toe front. 1.5 to 2.0 degrees negative camber in the rear, with the front a half-degree closer to 0 camber. Sway bars, torsion bars, and springs will change the balance of the car and you may get better results with different camber angles than the above. For instance, if you have a stock front sway bar and no rear, try setting the camber to even all the way around. You may need to tweak from there. You can go for 1/16" toe-out in front. It will help the initial turn-in response a bit, but the car will get somewhat "twitchy" on the street. You will have to actually drive the car every second--you can find yourself changing lanes accidentally when you look down to change radio stations... It gets a bit wearing after a while, but it is still mostly streetable. 0 front toe will mean you still have to pay some attention, and that the car will turn in a little more crisply than one with front toe-in. Camber: A little bit of negative camber (tops of wheels lean in toward the centerline of the car) is normal, and a good thing. Stock specs are for 0 camber front, -1/2 degree rear. I like to push those to -1.0/-1.5 (F/R) for an aggressively-driven street 914. More than that is getting into the realm of "racing" alignment, which is not really appropriate for the street. Rear toe-out, to quote someone else, "...is evil!!" A good way to swap ends. ************* ".... semi-trailing arms naturally tend to toe out under lateral loads, a trait that created the early 911’s fearsome reputation for lift-off oversteer" which resulted in the "evil tendency" to swap ends as DD points out **************** The generally accepted theory is that: Front Toe settings affect the quite important first third of cornering where you set up the line to the apex i.e. initial turn in. Rear Toe impacts upon acceleration through the apex and the attitude of the car on corner exit, i.e. whether understeer or oversteer shows up. (if they say it on the internet it must be true) "toe out in the rear helps with rotation because load transfers to the rear outside tire in a turn and since the rear tires don't turn (other than via dynamic toe), the slip angle is due only to the turning of the front wheels. However, if the outside tire (loaded tire) already has static toe *out* as it becomes loaded, the slip angle will be greater, and the rear will want to turn more outward than if the static toe were 0. However all the while you'd think the inside rear tire, pointing inward would counter this, but due to the load transfer to the outside tire, it's lateral grip effects are negligible compared to the outside tire." "I hear that this was something used on the old carrera cup cars." https://forums.nasioc.com/forums |
HalfMoon |
That above compilation was/is quite helpful information for all of us.
Thanks! |
Lo-Fi Version | Time is now: 31st July 2025 - 08:03 AM |
