Expert help from you body guys PLEASE, Door Gaps |
xperu |
May 26 2017, 08:27 AM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
I know door gaps is an old story, but I am at a crossroad in regard to what I am going to do with my beloved 914. I had inner stiffing kit installed and the guy did not install temp bracing to prevent heat shrinkage thus my door gaps puled in, so now I have very little gap between door and body. This problem is more prevalent on the passenger side then the drivers.
Later I had the Restoration Design long clamshells installed by another shop to stiffen the car. We also would attempt to possibly move the door gaps a little in the process. This did not work, but the long stiffeners really improved the stiffness of the car and it handles very well. My real question here is can anything be done to the car at this point to widen the door gaps? Other than the gap issue, the car is pretty much a new, all the bushing, suspension, engine rebuild etc. are done, the interior is in very good condition. I have had this 914 for 10+ years “my 4th one” it’s excellent for autocross, but the value of the car may be in jeopardy if I can’t resolve the gap problem. Any suggestion for you body guys would be greatly appreciated. Thanks Mike |
mgphoto |
May 26 2017, 09:50 AM
"If there is a mistake it will find me" Group: Members Posts: 1,338 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Post a few pictures of the problems all around the car.
burton73 |
May 26 2017, 10:00 AM
burton73 Group: Members Posts: 3,510 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I am not an expert but I have to say something as a warning to members.
A welder did a demonstration where he took a very strong thick pipe 6 ft. long and welded a line (bead) on it going the long dimension. As it cooled it curled in. A lot. You have strengthened the shit out of your longs and I think you would have to cut some and bend your car and weld it back with great care. Very slow letting it cool after each short weld. This is a major worry on buying a used 914 that has been welded by POs as far as what is going on with the past repairs? I think you will need the help of a pro. Bob B (IMG:style_emoticons/default/welder.gif) |
IronHillRestorations |
May 26 2017, 10:16 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
The only way to fix it now is by a competent frame shop, preferably one that's familiar with vintage uni-body cars
mb911 |
May 26 2017, 10:58 AM
914 Guru Group: Members Posts: 6,819 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Oh thats too bad but you can fix it. I welded supports in before i did anything. Also took measurement s but time will tell if it paid off when i am completely done..
914_teener |
May 26 2017, 11:30 AM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I am not an expert but I have to say something as a warning to members. A welder did a demonstration where he took a very strong thick pipe 6 ft. long and welded a line (bead) on it going the long dimension. As it cooled it curled in. A lot. You have strengthened the shit out of your longs and I think you would have to cut some and bend your car and weld it back with great care. Very slow letting it cool after each short weld. This is a major worry on buying a used 914 that has been welded by POs as far as what is going on with the past repairs? I think you will need the help of a pro. Bob B (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/agree.gif) You can cut them ....camber the car in the opposite direction and then reweld it. I would take it to somebidy that has done it before and can make sure your tub is straight. Not the local muffler shop. The longs are nothing more than formed 18 gauge sheet metal. Welding those kits in especially the amount of weld and way the welding is done....can have a tremedous effect. The stressed induced is in KIPS. I.ve done two Engman kits and you just cannot under estimate the time and amount of caution required to do it. Particulary on somebody elses car. |
TravisNeff |
May 26 2017, 11:48 AM
it can be fixed. I agree, go find a place that knows what they are doing.
http://www.914world.com/bbs2/index.php?sho...l=gaps&st=0 |
mskala |
May 26 2017, 11:50 AM
I know next-to-nothing, but would it work if you had at least the longs to bare metal,
repeat heating part of the long to a low temp like 300F, brace solidly only as it cooled? Basically reverse of the welding shrinkage problem. |
mb911 |
May 26 2017, 12:27 PM
I know next-to-nothing, but would it work if you had at least the longs to bare metal, repeat heating part of the long to a low temp like 300F, brace solidly only as it cooled? Basically reverse of the welding shrinkage problem. It would need to get a but hotter so the metal was in a plastic state. That is how we stress relieved new aircraft fuselage when pulling them out of a fixture. |
xperu |
May 26 2017, 01:58 PM
May 26 2017, 02:12 PM
The wrong way to fix it would be to just grind the edges of the doors. It's been done before.
burton73 |
May 26 2017, 02:33 PM
Even if you have braced the car the amount of stress put on the car are huge.
Frist you have to think that the car is now in many layers because of the Engelmann long kit that is over the inside of the longs. Plus the exterior long clamshells are another layer. The idea to grind the doors may not be right but if they close OK and the top goes on the car and fits, and the windows close you could do that. Pars of doors are cheep as well to try it. Sounds like you have been driving your car so they may fit and you are bugged on the gaps. The value of our cars will be scrutinized in the further as the price just keeps going up. Cars that have had restoration done will need to have full documentation on the work with detailed pictures for further buyers to review. There have been so many 914 that have had patches done to them that the cars may or may not be in restored shape. Some people think that there is a Magic Bullet to stop rust. There really is only cutting it out back to solid steel and doing the right job on fixing it. This board is a place where people car go to see what a person has done to bring their car back from almost junk. Fix them right and hopefully they will last for 40 more years. Fresh paint jobs will hide a lot. Just like in a house. Get a fresh paint job and it covers up the years of damage and people cannot always find the problems till some time has passed and it rains or is windy Bob B |
xperu |
May 26 2017, 03:04 PM
[quote name='burton73' date='May 26 2017, 03:33 PM' post='2489902']
Even if you have braced the car the amount of stress put on the car are huge. Frist you have to think that the car is now in many layers because of the Engelmann long kit that is over the inside of the longs. Plus the exterior long clamshells are another layer. The idea to grind the doors may not be right but if they close OK and the top goes on the car and fits, and the windows close you could do that. Pars of doors are cheep as well to try it. Sounds like you have been driving your car so they may fit and you are bugged on the gaps. The value of our cars will be scrutinized in the further as the price just keeps going up. Cars that have had restoration done will need to have full documentation on the work with detailed pictures for further buyers to review. There have been so many 914 that have had patches done to them that the cars may or may not be in restored shape. Some people think that there is a Magic Bullet to stop rust. There really is only cutting it out back to solid steel and doing the right job on fixing it. This board is a place where people car go to see what a person has done to bring their car back from almost junk. Fix them right and hopefully they will last for 40 more years. Fresh paint jobs will hide a lot. Just like in a house. Get a fresh paint job and it covers up the years of damage and people cannot always find the problems till some time has passed and it rains or is windy Bob B Well my top fits fine and my windows roll up and seal. The passenger door must be slammed to close it tight, to open I open from the inside, thou side handle is very tight so I don't want to brake it. I my be able to adjust the door latch, but really don't know how at this point. I must do something to fix the problem, I will take the advice from all and make a decision. I just retired so money is not as plentiful. Mike |
914_teener |
May 26 2017, 04:18 PM
Fly Rick Ollah down..... feed him and pay him and he will fix you car. (IMG:style_emoticons/default/beerchug.gif)
Or read the thread that was posted and do it yourself. |
burton73 |
May 26 2017, 04:38 PM
Mike,
Lets see the pictures of the gaps. The right door may need an adjustment. To open and maybe you just grind the door to look right as Perry said. One or the guys can help you with the latch. Texas is a big state. Who do you know in Texas that could look at it? Here in Southern California we have a lot of tenner brothers. Well we have a lot of cars. You spoke of the fear of the value of your car for resale that may be some time off. Bob B |
xperu |
May 27 2017, 09:34 AM
SixerJ |
May 27 2017, 10:16 AM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
Wow, that really is tight and almost certainly in need some (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) to open up. I'm guessing at this point you have no method of recourse with the two shops?
What does the other side look like? |
mb911 |
May 27 2017, 10:21 AM
Porta power?
xperu |
May 27 2017, 10:25 AM
Wow, that really is tight and almost certainly in need some (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) to open up. I'm guessing at this point you have no method of recourse with the two shops? What does the other side look like? The drivers side is out of tolerance, but better then the passenger side. The guy who screwed it up is no longer in business "for good reason". I told him to brace the openings before welding and I even gave him the drawing showing all th 914 dimensions', but he went out on his own path. I was sick over it, but the harm was done. Mike |
May 27 2017, 10:40 AM
After seeing the pics, I'll 2nd my earlier post.
Before I saw the pics, I thought you might be able to "cheat" by doing the edge grind and latch hack, but this is way beyond that. So sorry. If you have any relationship with legal counsel, I'd at least file a suit. Take it to a frame shop and see what the cost to pull it straight, and sue for that amount. That guy has caused damage to your car, and is responsible. |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:43 AM |
