Bus 2.0l vs 1.7 914 Motor Dilemma |
Montroe |
May 27 2017, 11:02 PM
Newbie Group: Members Posts: 21 Joined: 8-August 03 From: Port Saint Lucie, FL Member No.: 999 |
I recently purchased a 74 914 with what I thought was a 1.8l engine with low compression on all 4 cylinders. My plan was to get the heads cleaned up and have new valves and guides installed and replace the pistons and cylinders with a 94mm set. After removing the engine, I found that the block does not have ID numbers in either location, the heads are 2.0l bus heads 022 101 372G and the pistons and cylinders are 94mm. If it is a bus block, the dipstick has been relocated. I also have a 1.7l long block W0093163 with 022 101 372 heads that is also in need of refreshing. So, should I have larger valves (42mm/37.7mm) installed in the unidentified (possibly bus) block and go with 96mm P&C's or go with the 914 1.7l block and have the heads opened up to accept 96mm P&C's and maybe have larger valves installed as well? Either setup will be fed by Weber 40 IDF carbs. Thanks in advance for the advice.
914Sixer |
May 28 2017, 06:37 AM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Use the 1.7 block and the rest of the 2.0 bus parts. All the internals are interchangeable. You can use 96 mm PC because they are slip in. Use the bus heads. You do not say what you are using for fuel.
Montroe |
May 28 2017, 06:52 AM
Use the 1.7 block and the rest of the 2.0 bus parts. All the internals are interchangeable. You can use 96 mm PC because they are slip in. Use the bus heads. You do not say what you are using for fuel. Thanks for the response. I was planning to use regular 89 octane unleaded. Is there a reason to use premium? |
porschetub |
May 28 2017, 05:03 PM
Use the 1.7 block and the rest of the 2.0 bus parts. All the internals are interchangeable. You can use 96 mm PC because they are slip in. Use the bus heads. You do not say what you are using for fuel. (IMG:style_emoticons/default/agree.gif) and hear the 1.7(W0) block is the good one to use ,have a good one in my collection,bus cases get a much harder time,seen a lot of cracked heads on these to due to overheating also. Be aware fitting larger valves needs to be done by a very experienced shop,the average engine rebuilder has no idea of how to fit new seats in aircooled heads. |
Bob L. |
May 28 2017, 06:05 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Use the 1.7 block and the rest of the 2.0 bus parts. All the internals are interchangeable. You can use 96 mm PC because they are slip in. Use the bus heads. You do not say what you are using for fuel. Thanks for the response. I was planning to use regular 89 octane unleaded. Is there a reason to use premium? I think he meant fuel injection/carbs/microsquirt |
Montroe |
May 28 2017, 07:16 PM
Thanks for the info guys. I'm running Weber 40 IDF carbs.
larryM |
May 29 2017, 09:54 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
- the 2.0 bus heads have a different "square" exh port - won't match up to 914 headers
you will have to make custom exhaust otherwise it's a cheap & easy way to have a 2.0 Use the 1.7 block and the rest of the 2.0 bus parts. All the internals are interchangeable. You can use 96 mm PC because they are slip in. Use the bus heads. You do not say what you are using for fuel. |
jcd914 |
May 29 2017, 11:12 PM
The earlier 2.0L bus heads are "oval port", the same as 914.
Not sure when the change over to "square port" heads (really rectangular ports) My 78 2.0L bus had the "oval port" heads although some parts sources indicated they should have been "square port" heads. Jim |
Montroe |
May 30 2017, 06:40 AM
Thanks LarryM and JCD914. My 2.0l bus heads have oval ports.
McMark |
May 30 2017, 07:06 AM
Use either case (depending on which one is in better shape).
Use the 2.0 crank and rods. Get new AA 96mm pistons and cylinders. Get a cam from the Type4Store. Get new 2.0 bare heads from AA and have them assembled by someone who knows T4 heads. |
porschetub |
May 30 2017, 03:40 PM
The earlier 2.0L bus heads are "oval port", the same as 914. Not sure when the change over to "square port" heads (really rectangular ports) My 78 2.0L bus had the "oval port" heads although some parts sources indicated they should have been "square port" heads. Jim Have seen oval port heads from 2 litre bus I have one in my stash,if I remember correctly they have rather small valves compared to the 914,the 1.8 bus heads seem to have largest valves of the bus heads I have got. All the bus heads I have are from ROW carbed engines so there may be a difference in spec to the US ones. |
Montroe |
May 30 2017, 04:48 PM
The earlier 2.0L bus heads are "oval port", the same as 914. Not sure when the change over to "square port" heads (really rectangular ports) My 78 2.0L bus had the "oval port" heads although some parts sources indicated they should have been "square port" heads. Jim Have seen oval port heads from 2 litre bus I have one in my stash,if I remember correctly they have rather small valves compared to the 914,the 1.8 bus heads seem to have largest valves of the bus heads I have got. All the bus heads I have are from ROW carbed engines so there may be a difference in spec to the US ones. Thanks for the response my friend. The heads are currently at a local shop (Xtreme Cylinder Heads) in Palm City, FL being rebuilt with 42mm intake and 36mm exhaust valve. Xtreme specializes in air cooled Porsche and VW heads. Estimated cost is between $500-$600 for the work plus the cost of the valves and springs which I will provide. I ordered the valves and springs from European Motorworks in Hawthorne, CA. The original valves were 37.5mm and 33mm so you're right, rather small for my application. |
Lo-Fi Version | Time is now: 28th April 2024 - 03:11 PM |
