FS Resored Front 15 MM Sway Bar $350 plus shipping, New Porsche bushings, Powder Coated Bar, New SS hardware, Zinc Plated parts |
bdstone914 |
May 29 2017, 07:58 AM
bdstone914 Group: Members Posts: 4,508 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Pictures to be added soon.
This is a very clean front sway bar I restored. You need the triangular mounts installed on the car to use this. Not included but available from several sources. The bar was powder coated semi gloss black. All other sway bar parts were stripped and zinc plated. New stainless steel bolts, nuts, lock washers and added load washers were added to prevent rusting. Genuine Porsche bushings were replaced in the drop links and sway bar triangular cups. Not pictured but included are SS bolts, washers, and lock washers that hold the sway bar triangular cups to the body. These are getting harder to find. $350 plus shipping. In the U.S. it will cost about $25 to ship. Bruce |
bobt4945 |
May 30 2017, 11:07 AM
Newbie Group: Members Posts: 3 Joined: 29-July 14 From: MN. Member No.: 17,700 Region Association: Upper MidWest |
Nice!!!
GaroldShaffer |
May 30 2017, 12:57 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
That is a great deal! The amount of work needed to clean & prep all those parts, powder coat / re-plate AND the bushings & hardware. Save yourself a ton of time & effort and pick this set up. If I needed it would be all over this.
Very nice Bruce, very nice! |
johnhora |
May 30 2017, 01:32 PM
Senior Member Group: Members Posts: 865 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Damn Bruce that's Pretty!
bdstone914 |
May 30 2017, 01:44 PM
914Sixer |
May 30 2017, 03:17 PM
914 Guru Group: Members Posts: 8,863 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
A lot of work went into getting the parts that clean! (IMG:style_emoticons/default/aktion035.gif)
amfab |
May 30 2017, 08:10 PM
Member Group: Members Posts: 391 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
Hi Bruce,
Is the factory 15 mm? Would this be a decent set up for mild street? I was looking to buying a 19mm Tarret. -Andrew |
bdstone914 |
May 30 2017, 09:00 PM
Hi Bruce, Is the factory 15 mm? Would this be a decent set up for mild street? I was looking to buying a 19mm Tarret. -Andrew Yes ,this is a stock bar. The Tarrett bar is great and has adjustability and stiffer settings. Do you have the sway bar mounts on the body and A arms? |
EdwardBlume |
May 31 2017, 07:25 AM
Man, what a beauty Bruce. I'll have to find you when and if I decide to take Dad's car back to stock! Nice work! (IMG:style_emoticons/default/aktion035.gif)
amfab |
May 31 2017, 09:52 AM
Hi Bruce, Is the factory 15 mm? Would this be a decent set up for mild street? I was looking to buying a 19mm Tarret. -Andrew Yes ,this is a stock bar. The Tarrett bar is great and has adjustability and stiffer settings. Do you have the sway bar mounts on the body and A arms? I have the tabs and when I put in the gas tank I bought from you a couple of months ago I will be cutting and welding to set up for a sway bar. I like the adjustability of the Tarret, I worry though that even at the lowest it may be too stiff. Then again, I am running stock 914 torsion bars. I have never dealt with a sway bar on the front of a 914 before so I have no experience with how much it will change the ride. I would like the car a little stiffer, but I do not wanna go too much because the roads around here suck and I will be driving the car daily. Thanks -Andrew |
bdstone914 |
Jun 16 2017, 10:55 AM
Still have three complete restored sway bars. PM's sent to original inquires. They get first choice.
pete000 |
Jun 16 2017, 11:02 AM
Gotta love fresh CAD plating !
yellowporky |
Jun 17 2017, 11:15 AM
Member Group: Members Posts: 422 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
Pm sent
Wyvern |
Jul 31 2017, 03:51 PM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
That is nice stuff .... This is next on my "list" great info and resources .... Thanks
deemsriddle |
Jul 31 2017, 05:28 PM
Newbie Group: Members Posts: 15 Joined: 1-January 17 From: Ringgold GA Member No.: 20,717 Region Association: South East States |
Pictures to be added soon. This is a very clean front sway bar I restored. You need the triangular mounts installed on the car to use this. Not included but available from several sources. The bar was powder coated semi gloss black. All other sway bar parts were stripped and zinc plated. New stainless steel bolts, nuts, lock washers and added load washers were added to prevent rusting. Genuine Porsche bushings were replaced in the drop links and sway bar triangular cups. Not pictured but included are SS bolts, washers, and lock washers that hold the sway bar triangular cups to the body. These are getting harder to find. $350 plus shipping. In the U.S. it will cost about $25 to ship. Bruce Do you still have a set left? Shipping zip code will be 37412, a business. |
JC 914-73 |
Aug 1 2018, 07:14 AM
Newbie Group: Members Posts: 12 Joined: 25-June 18 From: Vancouver, BC Member No.: 22,252 Region Association: Canada |
Hello, I know the post is over a year old, just wondering if you still have a set available.
Very well done restoration! --jOhn Thx |
Cairo94507 |
Aug 1 2018, 07:30 AM
Michael Group: Members Posts: 9,703 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
That sway bar is absolutely representative of Bruce's work. All of his stuff is done to that level. Great work and thanks for always making great parts available for our cars. (IMG:style_emoticons/default/beerchug.gif)
DRPHIL914 |
Aug 1 2018, 07:51 AM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I would love to get one of those as well!
bdstone914 |
Aug 1 2018, 02:45 PM
JC 914-73 |
Aug 1 2018, 08:08 PM
Thx for the reply.
Regards --j |
Lo-Fi Version | Time is now: 19th April 2024 - 11:44 AM |
