FS SSS Super Shiny Stuff |
bdstone914 |
May 29 2017, 09:19 AM
bdstone914 Group: Members Posts: 4,508 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Steel Early type Gas Caps $30 Four available. New seals will be included.
Hold down plate and bolt for spare tire $30 Two or more sets. Near Perfect sets. Fuel Rails and injector hold down set of 6 parts $40. Two or more correct sets. Several more with both rails having pressure test ports. It is reported the a test port on the Passenger side can interfere with the MPS mounting. Controlled by size and shape of the elbows on the fuel injectors to fuel rails. Voltage regulator Covers. $15 each , 6 available. Replated clear zinc. There are some imperfections in plating where the wires were wrapped around them. Various markings on the tops. Pain in the butt to clean and polish. Attached thumbnail(s) |
May 29 2017, 09:36 AM
914-6 GT in waiting Group: Members Posts: 19,223 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Looks great!
gcrotvik |
May 29 2017, 11:11 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I will take 2 sets of the super shiny, near perfect spare hold downs.
Bartlett 914 |
May 29 2017, 01:24 PM
Advanced Member Group: Members Posts: 2,214 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Steel Early type Gas Caps $30 Four available. New seals will be included. Hold down plate and bolt for spare tire $30 Two or more sets. Near Perfect sets. Fuel Rails and injector hold down set of 6 parts $40. Two or more correct sets. Several more with both rails having pressure test ports. It is reported the a test port on the Passenger side can interfere with the MPS mounting. Controlled by size and shape of the elbows on the fuel injectors to fuel rails. Voltage regulator Covers. $15 each , 6 available. Replated clear zinc. There are some imperfections in plating where the wires were wrapped around them. Various markings on the tops. Pain in the butt to clean and polish. I would like a gas cap |
BillC |
May 29 2017, 03:01 PM
Senior Member Group: Members Posts: 534 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
forrestkhaag |
May 29 2017, 05:25 PM
Hey Bruce: Nice work having inspected them in person a couple of days ago. And to update, your pedal cluster solved a world of hurt / beautiful work / and I owe you my core as well. Your nuts were too big for Kieth's studs / I will return them when I get your core back .. (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/beerchug.gif)
Olympic 914 |
May 29 2017, 05:49 PM
Group: Members Posts: 1,661 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
I would also like a gas cap.
PM sent |
bdstone914 |
May 29 2017, 07:00 PM
Hey Bruce: Nice work having inspected them in person a couple of days ago. And to update, your pedal cluster solved a world of hurt / beautiful work / and I owe you my core as well. Your nuts were too big for Kieth's studs / I will return them when I get your core back .. (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/beerchug.gif) I disagree that my nuts are too big. Keith's stud problem is his problem and it is already TMI. Oh, and glad to here the pedal set did the trick. |
DRPHIL914 |
May 30 2017, 07:46 AM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i will take one of each-
fuel rail stuff, gas cap, spare hold down and the voltage regulator cover, |
bahnzai |
May 30 2017, 04:38 PM
Member Group: Members Posts: 305 Joined: 26-July 06 From: Columbia, SC Member No.: 6,509 Region Association: South East States |
Bruce,
I will take one of the gas caps, if you still have some. Just let me know how to send funds. Thanks! Danny |
MikeInMunich |
Jul 15 2017, 06:22 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Wow Bruce, nice work! (IMG:style_emoticons/default/blink.gif)
I've been thinking about your pedal clusters recently because my clutch pedal is squeaking when I depress it. Gunnex isn't getting in there good enough to stop it, although it doesn't squeak anymore if I press downward rapidly. I'm going to take it out and clean it up better than I can with it still installed. |
bdstone914 |
Jul 15 2017, 06:56 AM
Wow Bruce, nice work! (IMG:style_emoticons/default/blink.gif) I've been thinking about your pedal clusters recently because my clutch pedal is squeaking when I depress it. Gunnex isn't getting in there good enough to stop it, although it doesn't squeak anymore if I press downward rapidly. I'm going to take it out and clean it up better than I can with it still installed. Just pull the pedal board as removing it does not give any better access internally. Never used Gunnex but many lubes deteriorate the plastic bushings. Turns them into mush. I use bronze bushings and synthetic grease. Or i can build you one without out a core return and you swap it out. |
Spoke |
Jul 15 2017, 09:16 AM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I'm interested in a SSS gas cap. PM sent
DRPHIL914 |
Nov 9 2017, 07:50 AM
do you still have a set of the fuel rails and hold downs?
Phil |
tmaney |
Nov 9 2017, 10:58 AM
Newbie Group: Members Posts: 15 Joined: 22-July 03 From: Northern Virginia Member No.: 932 Region Association: MidAtlantic Region |
Bruce, I would like to have an early gas cap if one is still available. Tim
Retroracer |
Nov 9 2017, 04:37 PM
Senior Member Group: Members Posts: 608 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
RE: Gas caps; do you have a good known source for the seals?
Mikey914 |
Nov 9 2017, 04:59 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
bdstone914 |
Nov 10 2017, 06:44 AM
(IMG:style_emoticons/default/agree.gif) That is where I got the seals for the ones I had for sale. |
bdstone914 |
Nov 10 2017, 06:46 AM
bdstone914 |
Nov 10 2017, 06:48 AM
Lo-Fi Version | Time is now: 19th April 2024 - 06:02 PM |
