dash lights |
dash lights |
tomh |
May 29 2017, 11:11 PM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
Driving home tonite my interior dash lights were not working, both the dash and counsel gauge lights were out. All exterior lights were working fine including the fogs.
The fog light pull switch dose light up when pulled. The center cabin light also did not work. Any thoughts, if its a ground wire whats the most likely place i would find it. I did just recently change all the fuses with new ones. Thanks |
oakdalecurtis |
May 30 2017, 01:50 AM
Oakdalecurtis Group: Members Posts: 1,323 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Not sure what year car you have, but the best thing you can do is to familiarize yourself with these PP electrical diagrams. The more you look at them, the better you get at understanding them and how to use them. I use a small test light alone or in conjunction with a small AA battery power pack with alligator clip leads to test wires, grounds and wire lead continuity all the time.
http://www.pelicanparts.com/914/914_electrical_diagrams.htm |
porschetub |
May 30 2017, 03:10 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
My headlight switch dimmer went to ground and popped the instrument lamp fuse,I just bypassed it so lamps were on full brightness,why you need to dim these weak lights in beyond me anyway.
oakdalecurtis |
May 30 2017, 03:26 PM
SirAndy |
May 30 2017, 03:36 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Check your fuses first before you spent any time or money.
Rotate them by hand, sometimes they look OK but will fall apart if you rotate them. If it is a fuse and it keeps blowing, check the defroster light on top of the center tunnel, just before the shifter, the power to that light can easily short out since the back isn't insulated, which causes the fuse to blow. (IMG:style_emoticons/default/popcorn[1].gif) |
tomh |
May 30 2017, 10:11 PM
Great info, I figured there would be a good place to start looking,
GregAmy |
Jul 3 2017, 06:00 AM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Check your fuses first before you spent any time or money. Rotate them by hand, sometimes they look OK but will fall apart if you rotate them. If it is a fuse and it keeps blowing, check the defroster light on top of the center tunnel, just before the shifter, the power to that light can easily short out since the back isn't insulated, which causes the fuse to blow. (IMG:style_emoticons/default/popcorn[1].gif) Bump! Any others to look for while I've "assumed the position"? I'm popping this fuse now, too. Or any other "yeah, they do that here too" places to check? Porsche Jesus, please let this be something easy... Edit: actually, in re-reading the original post, I may have a different issue. I'm losing the entire gauge console: no indicators, no gauges, fuel, oil, and tach goes dead. That's a different circuit, as I recall. Any easy looks for that one? Edit 2: Oh, Porsche Jesus, this is looking nasty. That fuse serves us a TON of wiring, including rear stop lamps...if that's a bum wire someplace it will be a bee-otch to isolate... |
Dave_Darling |
Jul 3 2017, 09:19 AM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
License plate lights. If they're hooked up backwards, you will pop the instrument lights fuse when you turn the lights on. Same power source for both in a 74+ car.
--DD |
GregAmy |
Jul 3 2017, 09:58 AM
License plate lights. If they're hooked up backwards, you will pop the instrument lights fuse when you turn the lights on. Same power source for both in a 74+ car. This was a sudden problem, starting last week. Nothing has changed on the car in quite a bit, car has been running fine... Edit: disregard, this was in response to the OP. |
Mikey914 |
Jul 3 2017, 10:40 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
chaffing wire? should be simple enough to find, just a pain in the dash to get up under there.
Clean the grounds to get better voltage, however the LEDs work on much less current so they are nice and bright. Also the incandescent bulbs are actually "burning" causing a yellow orange color when not fully powered. The LEDs are a pure white light so when you replace them the gage will look much cleaner and more "new". The difference is very noticeable. The only caution is not to install one on the GEN light as it is a diode and will inhibit current on that circuit. That circuit provides a small charge to excite the field in your alternator. It will inhibit it from charging if you do. I do have them here if you need them. http://shop.914rubber.com/Instrument-light...m?categoryId=-1 |
tomh |
Jul 3 2017, 11:08 AM
Both of my licenses plate lights are disconnected and taped off.
Could this be my problem? |
Dave_Darling |
Jul 3 2017, 03:29 PM
If the tape comes off and one of the hot wires touches a ground, then it could be your problem.
--DD |
Lo-Fi Version | Time is now: 27th April 2024 - 11:03 PM |
