dash lights |
dash lights |
tomh |
May 29 2017, 11:11 PM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
Driving home tonite my interior dash lights were not working, both the dash and counsel gauge lights were out. All exterior lights were working fine including the fogs.
The fog light pull switch dose light up when pulled. The center cabin light also did not work. Any thoughts, if its a ground wire whats the most likely place i would find it. I did just recently change all the fuses with new ones. Thanks |
SirAndy |
May 30 2017, 03:36 PM
Resident German Group: Admin Posts: 41,632 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Check your fuses first before you spent any time or money.
Rotate them by hand, sometimes they look OK but will fall apart if you rotate them. If it is a fuse and it keeps blowing, check the defroster light on top of the center tunnel, just before the shifter, the power to that light can easily short out since the back isn't insulated, which causes the fuse to blow. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 12th May 2024 - 02:55 AM |
