dash lights |
dash lights |
tomh |
May 29 2017, 11:11 PM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
Driving home tonite my interior dash lights were not working, both the dash and counsel gauge lights were out. All exterior lights were working fine including the fogs.
The fog light pull switch dose light up when pulled. The center cabin light also did not work. Any thoughts, if its a ground wire whats the most likely place i would find it. I did just recently change all the fuses with new ones. Thanks |
SirAndy |
May 30 2017, 03:36 PM
Resident German Group: Admin Posts: 41,628 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Check your fuses first before you spent any time or money.
Rotate them by hand, sometimes they look OK but will fall apart if you rotate them. If it is a fuse and it keeps blowing, check the defroster light on top of the center tunnel, just before the shifter, the power to that light can easily short out since the back isn't insulated, which causes the fuse to blow. (IMG:style_emoticons/default/popcorn[1].gif) |
GregAmy |
Jul 3 2017, 06:00 AM
Advanced Member Group: Members Posts: 2,291 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Check your fuses first before you spent any time or money. Rotate them by hand, sometimes they look OK but will fall apart if you rotate them. If it is a fuse and it keeps blowing, check the defroster light on top of the center tunnel, just before the shifter, the power to that light can easily short out since the back isn't insulated, which causes the fuse to blow. (IMG:style_emoticons/default/popcorn[1].gif) Bump! Any others to look for while I've "assumed the position"? I'm popping this fuse now, too. Or any other "yeah, they do that here too" places to check? Porsche Jesus, please let this be something easy... Edit: actually, in re-reading the original post, I may have a different issue. I'm losing the entire gauge console: no indicators, no gauges, fuel, oil, and tach goes dead. That's a different circuit, as I recall. Any easy looks for that one? Edit 2: Oh, Porsche Jesus, this is looking nasty. That fuse serves us a TON of wiring, including rear stop lamps...if that's a bum wire someplace it will be a bee-otch to isolate... |
Lo-Fi Version | Time is now: 11th May 2024 - 03:36 PM |
