dash lights |
dash lights |
tomh |
May 29 2017, 11:11 PM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
Driving home tonite my interior dash lights were not working, both the dash and counsel gauge lights were out. All exterior lights were working fine including the fogs.
The fog light pull switch dose light up when pulled. The center cabin light also did not work. Any thoughts, if its a ground wire whats the most likely place i would find it. I did just recently change all the fuses with new ones. Thanks |
Dave_Darling |
Jul 3 2017, 09:19 AM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
License plate lights. If they're hooked up backwards, you will pop the instrument lights fuse when you turn the lights on. Same power source for both in a 74+ car.
--DD |
GregAmy |
Jul 3 2017, 09:58 AM
Advanced Member Group: Members Posts: 2,291 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
License plate lights. If they're hooked up backwards, you will pop the instrument lights fuse when you turn the lights on. Same power source for both in a 74+ car. This was a sudden problem, starting last week. Nothing has changed on the car in quite a bit, car has been running fine... Edit: disregard, this was in response to the OP. |
Lo-Fi Version | Time is now: 11th May 2024 - 07:32 PM |
