Heater Flappers for 914-6 |
Biggles |
May 31 2017, 02:03 PM
Member Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
Luke M |
May 31 2017, 03:37 PM
Senior Member Group: Members Posts: 1,369 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
The 4 doesn't have a hole on the cap where the 6 does.
See the pic. It's a 6 flapper box. I believe the hole is there to get rid of more heat/air from the heater boxes. Attached image(s) |
914Next |
May 31 2017, 07:06 PM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
rgalla9146 |
May 31 2017, 08:30 PM
All 914 6 flappers that I've seen are grey.
4 cyl. are black The valves will mount on the 6 heat exchangers The answer to your question depends on the position of the arms that operate the valves. |
Biggles |
Jun 1 2017, 01:33 AM
So apart from a hole and paint colour, is there any other difference?
Are the arm positions different? Look similar to me. What about pipe diameter? Can someone advise on OD diameter between the two please? 6 ones go for big $$$ and I can't see why -4 ones can't be made to fit. |
IAA1963 |
Jun 1 2017, 03:33 AM
Newbie Group: Members Posts: 46 Joined: 8-October 11 Member No.: 13,652 Region Association: None |
Yes, the pipe diameter below the cap is different. But that is all I have noted.
Biggles |
Jun 2 2017, 03:41 PM
Yes, the pipe diameter below the cap is different. But that is all I have noted. interesting as I note in an old Pelican post that a 4 flapper will work on the 6 car http://forums.pelicanparts.com/porsche-914...pper-boxes.html |
pete000 |
Jun 2 2017, 04:08 PM
JmuRiz |
Jun 6 2017, 07:57 AM
914 Guru Group: Members Posts: 5,423 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Phew...glad the /4 parts work for a 914/6 conversion with heat!
gereed75 |
Jun 6 2017, 09:59 AM
Senior Member Group: Members Posts: 1,240 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Running 4's on my six. They work normally. Thinking about opening holes on them similar to the six ones. Holes are there for a reason and I suspect that they flow some heat away from the exchangers/headers when the flapper is closed.
Good idea?? |
GeorgeRud |
Jun 6 2017, 11:51 AM
I also have used the -4 flapper boxes on my -6 conversion successfully, but now plan to drill the caps on the flapper boxes to increase the flow through the flapper boxes when the heat is closed off. I figure Porsche must have had a reason to design the -6 flapper boxes with a hole in the cap.
914Sixer |
Jun 6 2017, 02:41 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Get your hole saw out and make ANY -4 box into to a -6 box.
johnhora |
Jun 6 2017, 03:14 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Do a search on this ....been talked about before by some of our knowledgeable experts...the 6 has the flapper with a hole in it like in Luke's post....apparently this is so more air runs thru the HEs to help keep the engine cool when closed...with out it the engine over heats....
Biggles |
Jun 7 2017, 07:51 AM
I also have used the -4 flapper boxes on my -6 conversion successfully, but now plan to drill the caps on the flapper boxes to increase the flow through the flapper boxes when the heat is closed off. I figure Porsche must have had a reason to design the -6 flapper boxes with a hole in the cap. that's what i'll do with mine - being Porsche, they did these things for a reason ! |
gereed75 |
Jun 27 2017, 06:55 AM
Ok guys, we were wrong on this one.
Was mounting my 4 flapper valves and decided to add the six holes. Put in some holes and then decided to get my six flappers out to see how big the holes are supposed to be. While looking into the hole on the four flappers I noticed cutouts in the internal tube under the "mushroom" cap (they look like the cutouts on top of a castle tower). Then I looked at the six ones to compare. The castellated cutouts on the four version are twice the size as on the six version. So it looks like the four version passes just as much air through these larger vents as the six version does through the smaller vents and the hole. Maybe the engineers did this as a slight cost savings. While cutting the vents in the tube, might as well make them bigger and skip the extra step of adding the hole? So now I have double venting flappers. Makes me wonder if I am robbing some air that would otherwise flow through the shroud to the cylinder fins? Oh the horror! |
IAA1963 |
Jun 27 2017, 02:20 PM
Some pics of the different tube diameters of the /4 and /6 heater flappers ...
The one on the left is a /4 flapper box. The one in the middle a sandblasted unit from my original /6 and a new /6 flapper box on the right. |
Steve |
Jun 27 2017, 02:55 PM
914 Guru Group: Members Posts: 5,569 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Interesting... I have been running 4 banger ones with factory heat exchangers for 20 years with no problems. I just upgraded to mb911 heat exchangers and they still work fine.
Biggles |
Jun 27 2017, 03:15 PM
cheers for posting - useful to know. I was going to adapt the ones I've bought, but seems like no need
Ok guys, we were wrong on this one. Was mounting my 4 flapper valves and decided to add the six holes. Put in some holes and then decided to get my six flappers out to see how big the holes are supposed to be. While looking into the hole on the four flappers I noticed cutouts in the internal tube under the "mushroom" cap (they look like the cutouts on top of a castle tower). Then I looked at the six ones to compare. The castellated cutouts on the four version are twice the size as on the six version. So it looks like the four version passes just as much air through these larger vents as the six version does through the smaller vents and the hole. Maybe the engineers did this as a slight cost savings. While cutting the vents in the tube, might as well make them bigger and skip the extra step of adding the hole? So now I have double venting flappers. Makes me wonder if I am robbing some air that would otherwise flow through the shroud to the cylinder fins? Oh the horror! |
gereed75 |
Jun 27 2017, 04:58 PM
The diameters measured by IAA1963 are the diameters of the inner tubes. These do not effect fitment. Mount diameters appear to be the same.
Note the depth of the castlellated cutouts. The four cutouts are almost twice as deep as the six Not sure I could disassemble my six flappers like this as the tabs appear to be welded. Maybe not, I'll check later |
IAA1963 |
Jun 27 2017, 11:20 PM
The taps on the /6 flappers are not welded. The cover is quit easy to remove.
But the cover on the /4 flapper was welded and is difficult to remove. The second flapper of my /6 was damaged too much, so I wanted to mount the cover with the hole of my /6 to a NOS /4 flapper. But after removing the welded spots on the /4 flapper I have figured out that it does not fit due to the different tube diameters. Meanwhile I have a second grey NOS flapper to complete my set. |
Lo-Fi Version | Time is now: 26th April 2024 - 02:15 AM |
