More fuel pump problems, help????? |
mxdude914 |
May 11 2005, 10:21 PM
Member Group: Members Posts: 134 Joined: 20-July 03 From: Lodi, CA Member No.: 925 |
I finally thought i had the fuel pump problem worked out but i was wrong. I traced it back to starting when i reconnected the brakelight wire that the p/o had cut, when i connected it, the brake light fuse would blow. I messed with it for a while and found that if i just cut the back up light wire the problem was solved. This is when the fuel pump started cutting out, then i thought it was fixed when it did it again, actually a few times after it warms up, then i just take the main relay out and put it back in and it will sometimes run for a minute or two. Sometimes it wont start back up unless i use a diff. relay. Does anyone have any explanations?
Lo-Fi Version | Time is now: 19th May 2024 - 06:12 PM |
