F/S 1975 back date |
Harpo |
Jun 4 2017, 01:55 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Time to sell my car
Jake Raby type 4 2270 with full documentation (ceramic lifters, 911 swivel feet, etc) Trans has been rebuilt by Dr Evil & my self J west shifter Tangerine shift linkage All brakes have been replaced by PMB & McMark (S calipers in the front & M in the rear with no parking brake) Rear floor pan & fire wall curtesy of 914 LTD & restoration design All new interior - Seats, back pad, door panels, carpet & dash top New paint in 2016 New Rebel Racing Teflon bushings installed in the front control arms & ball joints Back dated the bumpers Coil over shocks on all four corners Triple gauge with calibrated oil temp senders Tangerine headers with evo2 muffler New Pirelli tires (4) Nice set of Fuchs New (911) half shafts with custom sway a way axles upgraded 5 stud 911 spindles so I can use the 911 fuchs New solid state relay board Rear control arms have been powder coated with new bearings & poly bronze bushings All new rubber seals from 914 rubber New S/S fuel line in the center tunnel from the gas tank. -6AN every where else Two tops, one factory and one smoked acrylic top I think it was called a WAS Because I have headers I have no heat or air for that matter Although I made a GT front bumper for this car I never put an aftermarket cooler. all factory New seatbelts and buckles Rennline floor boards, gas, clutch & brake pedal GE Night hawk LED head lights Things that need work JW Speaker fog lights with custom brackets bolted on but not wired Period correct radio rebuilt but not finished the install GT head light cables not finished installation Target front sway bar not fully installed - reinf. have been welded in $22,000 |
lostreasure |
Apr 29 2018, 06:33 PM
Newbie Group: Members Posts: 44 Joined: 24-June 13 From: new jersey Member No.: 16,048 Region Association: None |
Wheels in front are wider then rears? That should be corrected
Lo-Fi Version | Time is now: 8th May 2024 - 02:13 PM |
