Center Console Wiring |
tomh |
Jun 6 2017, 06:53 PM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
I need to know where the black with blue dots wire goes in the center counsel.
It's a wire that's coming up out of the tunnel area. I don't seem to have a place for it to connect to. It has a small female spade connector. |
wilchek |
Jun 6 2017, 06:57 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
tomh |
Jun 6 2017, 07:06 PM
Awesome,
Thanks |
wilchek |
Jun 6 2017, 07:08 PM
This one is a little easier to understand
http://www.914world.com/bbs2/index.php?showtopic=206117 Page half way down |
ljubodraz |
Jun 6 2017, 08:37 PM
Member Group: Members Posts: 64 Joined: 4-May 14 From: Chicagoland Member No.: 17,312 Region Association: Upper MidWest |
Don't know if you've seen them already but Bowlsby's site has a few diagrams regarding electrical for the center console that might be helpful as well.
http://bowlsby.net/914/Classic/TechNotebook.htm Look halfway down in the electrical section. |
brownaar |
Jun 7 2017, 06:57 AM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
If I'm thinking correctly, that's the wire that feeds power to the indicator lamp for the heater lever behind the shifter.
brownaar |
Jun 7 2017, 07:25 AM
yellow75 |
Jun 7 2017, 08:05 AM
Member Group: Members Posts: 88 Joined: 1-October 16 From: pittsburgh Member No.: 20,452 Region Association: None |
I need to know where the black with blue dots wire goes in the center counsel. It's a wire that's coming up out of the tunnel area. I don't seem to have a place for it to connect to. It has a small female spade connector. pretty sure its the light for the heater control lever on the tunnel. If you have a console it needs a brown wire to ground, if no console the unit/liht grounds itself with the screw that holds it to the tunnel. |
tomh |
Jun 7 2017, 10:34 AM
My question is, do these wires have to be connected or can they be just taped off and left alone or do they need to be connected to complete a circuit.
Porschef |
Jun 7 2017, 10:49 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
They dont have to be connected. Mine were under the carpet, unattached.
Made adding the console easy. |
brownaar |
Jun 7 2017, 11:50 AM
I would definitely tape off any bare connectors. Part of this wiring was fried on my car I suspect for this very reason. I had to repair that section. That wire has voltage on it when lights are on.
Lo-Fi Version | Time is now: 21st May 2024 - 11:58 AM |
