The Crest: Version 2, - This time, it gets framed |
tygaboy |
Jun 11 2017, 08:14 AM
914 Guru Group: Members Posts: 5,295 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I though you might enjoy seeing some details on this "build".
With "Crest Version 1" (my interpretation) being given away as a WCR award, I've decided to make some "improvements" to V2. This one will hang in my home office. As you may have noticed in my LS build (with things like the engine compartment panel), I most often have to build something and experience it physically before I know what I really like. Same thing is happening here. Comparing V1 and the pieces/cut patterns for V2, you can see I decided to add an additional layer to the main body area - I think that'll be more interesting and better balanced. The grid in the design is 4'x4' so you can see, this uses a bit of metal! I'm thinking I may do this one in stainless, depending on cost. And I have an idea for a wall frame that should be pretty neat. More on that as I get to it. Attached thumbnail(s) |
tygaboy |
Jun 12 2017, 09:40 AM
The cut parts on the table. I cut those little "locating holes" on all the parts which makes it a slam dunk to get each piece just where it's supposed to be.
Again, the differences with this version are the addition of the panels (show only in the upper right area) that will add dimension where previously, I just did cut lines. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 22nd May 2024 - 10:57 AM |
