Gauging interest for a 914 breather/puke tank, for 914/6 but could be modified to use on any engine combo |
Mark Henry |
Jun 13 2017, 11:13 AM
I built this as my very first aluminum TIG welding project, welds are definitely not up to Ben's standards, but I'm starting to get the hang of it. Bit more practice an I should have decent welds. Also the aluminum was a scrap sheet that been sitting outside for years, so that likely didn't help matters.
But overall seeing as it's my first effort I'm pretty happy with it. Would do a couple things different for a short run production, use the next size up petcock valve, weld the baffles in a bit different, etc. I made it to clear the factory trunk springs, but not intrude into the engine bay much. It has a petcock and a tube, so to drain you stick an oil pan under the /6 cooler and open the valve. It's fully baffled and holds over a quart of puke. The barb's are 1" but I could also check out what's involved with using AN fittings. I would likely have them power coated semi-gloss black. I have the patterns for it so it would be easy to make more. I have to check the price of materials, parts, powder coating, etc, but I'm thinking $150-$175, or $200 + ship and I supply the black braid hose and clamps. So is there any interest? (IMG:style_emoticons/default/confused24.gif) (IMG:http://www.914world.com/bbs2/uploads/post-26-1497237833.jpg)(IMG:http://www.914world.com/bbs2/uploads/post-26-1497237851.jpg) Attached thumbnail(s) |
SirAndy |
Jun 21 2017, 11:50 AM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Them green hoses were cheap ...
(IMG:style_emoticons/default/bye1.gif) (IMG:http://www.914world.com/bbs2/uploads/post-179-1255294222.jpg) |
Mark Henry |
Jun 21 2017, 12:47 PM
Are those rad/heater core hose? The guy at NAPA warned me that they would break down over time if used with oil. He did say 1" fuel line would work and I thought about covering that with braided expansion sleeve. He didn't have 1" fuel hose but said I should be able to get it at a truck supply shop. Not that it matters with my build, but personally I'm looking for a more correct looking solution. |
Lo-Fi Version | Time is now: 16th May 2024 - 08:38 AM |
