Gauging interest for a 914 breather/puke tank, for 914/6 but could be modified to use on any engine combo |
Mark Henry |
Jun 13 2017, 11:13 AM
I built this as my very first aluminum TIG welding project, welds are definitely not up to Ben's standards, but I'm starting to get the hang of it. Bit more practice an I should have decent welds. Also the aluminum was a scrap sheet that been sitting outside for years, so that likely didn't help matters.
But overall seeing as it's my first effort I'm pretty happy with it. Would do a couple things different for a short run production, use the next size up petcock valve, weld the baffles in a bit different, etc. I made it to clear the factory trunk springs, but not intrude into the engine bay much. It has a petcock and a tube, so to drain you stick an oil pan under the /6 cooler and open the valve. It's fully baffled and holds over a quart of puke. The barb's are 1" but I could also check out what's involved with using AN fittings. I would likely have them power coated semi-gloss black. I have the patterns for it so it would be easy to make more. I have to check the price of materials, parts, powder coating, etc, but I'm thinking $150-$175, or $200 + ship and I supply the black braid hose and clamps. So is there any interest? (IMG:style_emoticons/default/confused24.gif) (IMG:http://www.914world.com/bbs2/uploads/post-26-1497237833.jpg)(IMG:http://www.914world.com/bbs2/uploads/post-26-1497237851.jpg) Attached thumbnail(s) |
Mark Henry |
Jun 25 2017, 07:05 AM
Same area I mounted mine. (IMG:style_emoticons/default/smile.gif)
I still have to cut and re-weld the bungs, but I think I have the hose to weber rain hats figured out for a nice super clean install. For weber rain hats I'm going to offer it as a complete kit, puke tank, all hose, fittings, grommets and hardware. I'll try to post prototype pic's later today. The weber kit would also work for a dual carb /4, but you would have to drill a hole in your air cleaner top. I can easily make a version to use on stock FI /4's. I still need to know what size hose from the puke tank to stock /6 intakes. |
6freak |
Jun 25 2017, 09:39 AM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
Same area I mounted mine. (IMG:style_emoticons/default/smile.gif) I still have to cut and re-weld the bungs, but I think I have the hose to weber rain hats figured out for a nice super clean install. For weber rain hats I'm going to offer it as a complete kit, puke tank, all hose, fittings, grommets and hardware. I'll try to post prototype pic's later today. The weber kit would also work for a dual carb /4, but you would have to drill a hole in your air cleaner top. I can easily make a version to use on stock FI /4's. I still need to know what size hose from the puke tank to stock /6 intakes. You should also take into consideration the rubber stopper thingy that keeps the engine lid from hitting the trunk lid when its open ...sorta looks like your tank is right in line with that...no idea of the hose size (IMG:style_emoticons/default/smile.gif) |
Mark Henry |
Jun 25 2017, 09:49 AM
You should also take into consideration the rubber stopper thingy that keeps the engine lid from hitting the trunk lid when its open ...sorta looks like your tank is right in line with that...no idea of the hose size (IMG:style_emoticons/default/smile.gif) The top of the tank is a couple inches below the decklid. Just the picture depth of field. |
6freak |
Jun 25 2017, 12:13 PM
You should also take into consideration the rubber stopper thingy that keeps the engine lid from hitting the trunk lid when its open ...sorta looks like your tank is right in line with that...no idea of the hose size (IMG:style_emoticons/default/smile.gif) The top of the tank is a couple inches below the decklid. Just the picture depth of field. Right on! again nice work (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 12:51 PM |
