So THAT'S why I keep throwing belts, How does a break like this even happen? |
iankarr |
Jun 18 2017, 10:13 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi guys,
After I threw my second alternator belt I decided to investigate a bit deeper and discovered that the pulley is cracked. See pic. Is it practical/possible to replace just the pulley with the alt in the car? I guess I'd need a point of leverage to hold the pulley still while breaking the nut. Or...is it better to bite the bullet and remove the alternator and repair on the bench? I suppose the third option would be to replace the entire alternator "while I'm in there". Thoughts/advice? Thanks! Ian |
McMark |
Jun 19 2017, 08:27 AM
It's not uncommon for the pulley to be stuck on the shaft. If you can replace the pulley in the car, count yourself lucky. But if it sticks, just stop and pull the entire alternator.
Lo-Fi Version | Time is now: 6th May 2024 - 10:39 AM |
