Oil Temp gauge / sender |
Montreal914 |
Jun 18 2017, 10:22 PM
Senior Member Group: Members Posts: 1,559 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I've been seeing a temperature mismatch of about 20 degrees between my temp gauge and an actual thermocouple reading through the dipstick tube. Seems like the 911 temp gauge/sender mismatch is pretty common from what I've been reading. I've been using the standard 914 sender.
My gauge is a combination of various elements and therefore the actual whole gauge number cannot be used as a reference. Am I to understand that the temperature module was built in November 1980 as per the picture below? (IMG:style_emoticons/default/confused24.gif) I found this chart either here or Pelican. If my temp gauge was build in late 80, then I need to get a 911 606 112 sender. Will this fit in the standard taco plate or is it too long? I've been seing a lot of comments about late temp gauges being numberless which makes me wonder if I actually do have a 1980-81 gauge... |
Lo-Fi Version | Time is now: 16th May 2024 - 10:05 PM |
