Oil Temp gauge / sender |
Montreal914 |
Jun 18 2017, 10:22 PM
Senior Member Group: Members Posts: 1,544 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I've been seeing a temperature mismatch of about 20 degrees between my temp gauge and an actual thermocouple reading through the dipstick tube. Seems like the 911 temp gauge/sender mismatch is pretty common from what I've been reading. I've been using the standard 914 sender.
My gauge is a combination of various elements and therefore the actual whole gauge number cannot be used as a reference. Am I to understand that the temperature module was built in November 1980 as per the picture below? (IMG:style_emoticons/default/confused24.gif) I found this chart either here or Pelican. If my temp gauge was build in late 80, then I need to get a 911 606 112 sender. Will this fit in the standard taco plate or is it too long? I've been seing a lot of comments about late temp gauges being numberless which makes me wonder if I actually do have a 1980-81 gauge... |
arne |
Jun 19 2017, 09:33 AM
Serial Rescuer of old vehicles... Group: Members Posts: 734 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
Another thought - the build date of that gauge was 11/80, but that does not mean that it wasn't a replacement for an earlier car.
This could be tough to figure out. You may end up having to buy a new matching pair, or at least a used gauge that is clearly identified. |
Lo-Fi Version | Time is now: 2nd May 2024 - 07:38 AM |
