Oil Temp gauge / sender |
Montreal914 |
Jun 18 2017, 10:22 PM
Senior Member Group: Members Posts: 1,544 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I've been seeing a temperature mismatch of about 20 degrees between my temp gauge and an actual thermocouple reading through the dipstick tube. Seems like the 911 temp gauge/sender mismatch is pretty common from what I've been reading. I've been using the standard 914 sender.
My gauge is a combination of various elements and therefore the actual whole gauge number cannot be used as a reference. Am I to understand that the temperature module was built in November 1980 as per the picture below? (IMG:style_emoticons/default/confused24.gif) I found this chart either here or Pelican. If my temp gauge was build in late 80, then I need to get a 911 606 112 sender. Will this fit in the standard taco plate or is it too long? I've been seing a lot of comments about late temp gauges being numberless which makes me wonder if I actually do have a 1980-81 gauge... |
porschetub |
Jun 19 2017, 02:51 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Is that date stamp to indicate when it was made or model year ? the number on the very outside of the gauge face will confirm,I was sold a tach and it wasn't as advertised turned out to be a 86 from a 3.2.
The 3.2 tach uses a different signal than the earlier ones but my tachadapt will cover that. I have the same combo gauge and it is matched with a 150 degrees celsuis sender,I matched a new 50mm VDO to it and got close reading between the two,there is a VDO sender that you can cut to length but think it is only 1/8''npt ,I just used a reducer bush,not sure if you could use it on a T4 motor. Is it possible the one you showed in the pic will be too long (IMG:style_emoticons/default/confused24.gif) . |
Lo-Fi Version | Time is now: 2nd May 2024 - 04:36 AM |
