Amount of paint, Painting material |
georgegalla |
Jun 19 2017, 09:14 AM
Newbie Group: Members Posts: 2 Joined: 18-June 17 From: Corona Calif. Member No.: 21,193 Region Association: Southern California |
I'm in Southern Calif (Riverside).I'm having difficulty finding the original 1973 Bahia Red paint. Code L30E. I will be painting the door jambs and outside only.I want to use base coat and clear coat.Does anyone know how much paint and clear to order and where I might purchase it in Orange,San Bernardino or Riverside County
1TRICK6 |
Jun 19 2017, 09:35 AM
Newbie Group: Members Posts: 45 Joined: 13-July 11 From: Southern California Member No.: 13,313 Region Association: Southern California |
Try Finish Master in Corona.
Costa05 |
Jun 19 2017, 11:02 AM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
For what it is worth, i just went through a gallon of epoxy primer (two nice coats) body, jambs, both hoods inside and out, doors, rear trunk. Still need more to finish. Thinking gallon and a half of primer on my project. Guessing similar for base coat and clear.
Jun 19 2017, 12:30 PM
914-6 GT in waiting Group: Members Posts: 19,219 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Primer sprays much heavier than paint and clear. A gallon of paint is more than enough to paint a car. Never hurts to ask your supplier about the paint you are using. The good ones know their products.
Andyrew |
Jun 19 2017, 01:32 PM
^ Exactly.
I went through 3 gallons of primer on my car, Paint I went through 3/4 gallon and I sprayed the rear hood 3 times, the undersides of the hoods, the targa top twice and the body in 7 coats of single stage (I planned on wetsanding, as well as having enough material to wet sand it a couple more times down the road). Note that with paint you reduce it ~ 20%, plus the hardner so 1 gallon of paint makes 1.5gal+ sprayable. A base coat clear coat uses even less physical paint as you throw as many coats on as necessary for complete coverage then throw the clear on that ( as many coats as you want, typically 3 coats for good coverage, but I have seen high end shops do many more so they can wet sand it and still have many coats for protection. . |
Lo-Fi Version | Time is now: 18th April 2024 - 07:20 PM |
