Amount of paint, Painting material |
georgegalla |
Jun 19 2017, 09:14 AM
Newbie Group: Members Posts: 2 Joined: 18-June 17 From: Corona Calif. Member No.: 21,193 Region Association: Southern California |
I'm in Southern Calif (Riverside).I'm having difficulty finding the original 1973 Bahia Red paint. Code L30E. I will be painting the door jambs and outside only.I want to use base coat and clear coat.Does anyone know how much paint and clear to order and where I might purchase it in Orange,San Bernardino or Riverside County
Andyrew |
Jun 19 2017, 01:32 PM
^ Exactly.
I went through 3 gallons of primer on my car, Paint I went through 3/4 gallon and I sprayed the rear hood 3 times, the undersides of the hoods, the targa top twice and the body in 7 coats of single stage (I planned on wetsanding, as well as having enough material to wet sand it a couple more times down the road). Note that with paint you reduce it ~ 20%, plus the hardner so 1 gallon of paint makes 1.5gal+ sprayable. A base coat clear coat uses even less physical paint as you throw as many coats on as necessary for complete coverage then throw the clear on that ( as many coats as you want, typically 3 coats for good coverage, but I have seen high end shops do many more so they can wet sand it and still have many coats for protection. . |
Lo-Fi Version | Time is now: 5th May 2024 - 07:27 AM |
