pressure plate bolts |
JFG |
Jun 20 2017, 09:33 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
These are the m8 x1.25 x 6 fitting the pressure plate to the flywheel. I've been to porsche and they are showing as nla with no superceded part number. Can i use high tensile bolts grade 8.8 as these are available from an engineers supplier shop close by?
stugray |
Jun 20 2017, 11:55 AM
These are the m8 x1.25 x 6 fitting the pressure plate to the flywheel. I've been to porsche and they are showing as nla with no superceded part number. Can i use high tensile bolts grade 8.8 as these are available from an engineers supplier shop close by? Yes you can use generic 8.8 Bolts. The shear that they are under out at the edge of the pressure plate is nothing compared to that of the Flywheel bolts. |
Lo-Fi Version | Time is now: 25th May 2024 - 06:18 PM |
