Holy Smoking' 914!, Help! |
Dck356 |
Jun 23 2017, 08:38 PM
Newbie Group: Members Posts: 20 Joined: 9-April 12 From: Davidson, NC Member No.: 14,355 Region Association: South East States |
Good evening gents. I've been lurking in the background while working on my 74 2.0L. Purchased the car almost a year ago from a member here who had it sitting as a project for about 12 years. So far I've done the following:
- removed gas tank and had it cleaned/sealed - replaced all fuel lines with the SS kit from Tangerine - replaced fuel pump and fuel filter - pulled distributor; had a bad pertronix unit - added points, condenser, rotor, cap, plug wires - popped the distributor back in and set static timing So this afternoon, after 12 years of not running, it fired right up. Exciting right? Not so much... the exhaust began producing a ridiculous amount of blue/white smoke - lucky the fire department didn't show. Seriously hoping that this is a timing problem and not a worn out engine. Tomorrow I'll check the dwell, put the timing light on it at 27 degrees... and say a little prayer to the Porsche gods. Any thoughts or words of advice? Thanks in advance!! |
IronHillRestorations |
Jun 23 2017, 09:22 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Either it will get better or it will get worse there's no way of knowing without more diagnostics.
Engines that have sat for long periods are notorious for breaking rings, or ring sealing problems |
Lo-Fi Version | Time is now: 17th May 2024 - 07:56 PM |
