Holy Smoking' 914!, Help! |
Dck356 |
Jun 23 2017, 08:38 PM
Newbie Group: Members Posts: 20 Joined: 9-April 12 From: Davidson, NC Member No.: 14,355 Region Association: South East States |
Good evening gents. I've been lurking in the background while working on my 74 2.0L. Purchased the car almost a year ago from a member here who had it sitting as a project for about 12 years. So far I've done the following:
- removed gas tank and had it cleaned/sealed - replaced all fuel lines with the SS kit from Tangerine - replaced fuel pump and fuel filter - pulled distributor; had a bad pertronix unit - added points, condenser, rotor, cap, plug wires - popped the distributor back in and set static timing So this afternoon, after 12 years of not running, it fired right up. Exciting right? Not so much... the exhaust began producing a ridiculous amount of blue/white smoke - lucky the fire department didn't show. Seriously hoping that this is a timing problem and not a worn out engine. Tomorrow I'll check the dwell, put the timing light on it at 27 degrees... and say a little prayer to the Porsche gods. Any thoughts or words of advice? Thanks in advance!! |
rgalla9146 |
Jun 23 2017, 09:05 PM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Stuck rings, oil in cylinders, oil on top of heat exchangers.
Let it run. I bet it'll clear up. Two weeks ago I started a '73 T that had not run since 2001. Plenty of blue/white smoke. Slowly clearing up. Still a little today. But better every day. |
jkb944t |
Jun 23 2017, 09:36 PM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
Stuck rings, oil in cylinders, oil on top of heat exchangers. Let it run. I bet it'll clear up. Two weeks ago I started a '73 T that had not run since 2001. Plenty of blue/white smoke. Slowly clearing up. Still a little today. But better every day. (IMG:style_emoticons/default/agree.gif) I had the same thing happen when I bought a 1977 911 that had sat for 10+ years. It scared the hell out of me when I started it. It smoked like crazy for the first 10 minutes then it slowly cleared up completely. Jeff B |
Lo-Fi Version | Time is now: 17th May 2024 - 06:21 PM |
