914 and 550, both T4, One Cold Starts, the Other Doesn't, Why? |
Tastyplacement |
Jun 24 2017, 08:11 PM
Newbie Group: Members Posts: 39 Joined: 31-August 16 From: Austin, TX Member No.: 20,358 Region Association: MidAtlantic Region |
This is baffling to me. I have two type 4 cars, both have 914 motors and have a lot off commonality to them. My 914 starts cold no problem. My 550 replica is a total hassle to start cold.
The 914 which cold starts very easily: -1.8 liter motor -twin IDF 40 with no choke and no cold start circuit Main Jets are 115 Idle Jets are 55 carbs were recently completely rebuilt -Pertronix Ingnitor 1 points replacement The 550 replica: -2.3 liter motor Main jets are 155 Idle jets are 65 carbs seem great, but haven't been thoroughly cleaned recently -twin IDF 44 with no choke and no cold start circuit -Pertronix Ignitor 3 points replacement The 914, I pump the pedal once, car starts every time and is immediately steady. The 550, I have to pump the pedal 4 or 5 times and It'll fire quickly and die quickly. Once I do this a few times it'll run if I keep it at about 2000rpm by feathering throttle. Once it is warm, it's awesome. |
ChrisFoley |
Jun 26 2017, 09:31 AM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The 50s are too small for the 2.3L.
55 would be better, and probably is enough to set the idle mixture for easier cold starting. |
Tastyplacement |
Jun 26 2017, 11:23 AM
Thanks chris, I am going to try the 55s, which I have on order.
By the way, I got your shift linkage put in my 914 recently and it truly is spectacular... The 50s are too small for the 2.3L. 55 would be better, and probably is enough to set the idle mixture for easier cold starting. |
Lo-Fi Version | Time is now: 26th May 2024 - 08:57 AM |
