914 and 550, both T4, One Cold Starts, the Other Doesn't, Why? |
Tastyplacement |
Jun 24 2017, 08:11 PM
Newbie Group: Members Posts: 39 Joined: 31-August 16 From: Austin, TX Member No.: 20,358 Region Association: MidAtlantic Region |
This is baffling to me. I have two type 4 cars, both have 914 motors and have a lot off commonality to them. My 914 starts cold no problem. My 550 replica is a total hassle to start cold.
The 914 which cold starts very easily: -1.8 liter motor -twin IDF 40 with no choke and no cold start circuit Main Jets are 115 Idle Jets are 55 carbs were recently completely rebuilt -Pertronix Ingnitor 1 points replacement The 550 replica: -2.3 liter motor Main jets are 155 Idle jets are 65 carbs seem great, but haven't been thoroughly cleaned recently -twin IDF 44 with no choke and no cold start circuit -Pertronix Ignitor 3 points replacement The 914, I pump the pedal once, car starts every time and is immediately steady. The 550, I have to pump the pedal 4 or 5 times and It'll fire quickly and die quickly. Once I do this a few times it'll run if I keep it at about 2000rpm by feathering throttle. Once it is warm, it's awesome. |
porschetub |
Jun 29 2017, 11:34 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Wow huge jets...why,those mains are massive, what vents are you running ,if that makes it go your vents are too big.
Bigger is not better,camshafts are the same (IMG:style_emoticons/default/sad.gif) |
ChrisFoley |
Jun 30 2017, 08:38 AM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Wow huge jets...why,those mains are massive, what vents are you running ,if that makes it go your vents are too big. Those aren't too large for a 2.3L with a long duration camshaft. It might even call for bigger mains and bigger airs. I wouldn't hesitate to put 36mm venturis in those 44s if the engine is configured for top end performance. |
Lo-Fi Version | Time is now: 18th May 2024 - 07:51 PM |
