IS a perfect idle realistic with a 1.7 D-jetrinic?, Idle is low after hot restarts |
pmead |
Jun 25 2017, 03:45 PM
Newbie Group: Members Posts: 20 Joined: 5-February 17 From: Lewes Delaware Member No.: 20,813 Region Association: MidAtlantic Region |
Ok, I know its been discussed many times, and have searched the archives but I still have a small idle issue. Car is a 73 1.7 with stock injection. Car runs great, great mileage, runs cool, quiet, etc..... but after a hot start will idle slow (around 200-250) for about 2 miles of driving then returns to 950 and is great until I shut down for a few minutes and start it again. Then the idle will drop for a couple of miles again. I have tested every component and all components are in spec. (car does not have deaccel valve) Yesterday I replaced all vacuum lines, intake gaskets and sleeves injector seals etc.. I was hoping I had a phantom vacuum leak but car still does the same thing. The cold starts are fine. I have read that some people have spaced the cylinder head temp sender away from the head. Is this the cure????? By the way, timing, dwell, valve lash, compression are all correct. Am I expecting to much of the D-jet?? The car does not stall, but it does not seem correct and I like things to be correct. Any Ideas would be appreciated.
Rand |
Jun 25 2017, 04:38 PM
You asked multiple questions.
* Yes a perfect idle is realistic. My 1.7 and 2.0 djet cars have all idled flawlessly in all conditions once dialed in. From cold start to any temp. * No, spacing the sensor away from the head is not a cure, it's a hack. * No, you are not expecting too much from djet. If everything is in spec, they run perfectly. Start, cold, hot, altitude, nothing should affect it. If it's not acting perfectly, something is wrong. Might be a good time to clean up the dizzy, and make sure the advance plates can move freely through their full range. Quite possibly contributing here, and no matter what, need to know that anyway. |
Lo-Fi Version | Time is now: 14th May 2024 - 05:14 PM |
