Shift Linkage bar Adjustment Tips |
dcecc1968 |
Jun 26 2017, 12:20 PM
Member Group: Members Posts: 252 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
After 9 MONTHS of letting my 914 sit in my garage (unworked on and undriven), I decided to get my two teenage boys and do a couple of small jobs I've been postponing. One of the jobs we did was to install a side-shifter transmission cover that I bought from 914 rubber 9 months ago. Part of that job is disconnecting the shift rod to slide the boot and cover on which should have involved just unscrewing the two cone screws and sliding the lower shift rod out, but somebody.... didn't look at the Hayes Manual close enough to find the second cone screw and decided to disconnect the gear shift assembly from the shift rod.
Long story short, we put it back together (boy I had heck of a time getting that original cotter-pin style locking clamp to tighten up) and then I realized that I must have rotated the shift rod differently when I re-clamped the gear shift assembly to the shift rod as I could barely get the transmission into 1st and Reverse. Is there any advice out there for adjusting the rotation of and insertion length of the shift rod in the clamp so that all gears can be reached besides trial and error? I would welcome any and all help. -Don Ceccarelli |
dcecc1968 |
Jun 27 2017, 06:09 AM
Thanks Chris. I'll try anything not to have to mess with that plastic cover again.
PS - did you mean put it in 4th gear by moving the shift lever to the right and "forward", or to "5th gear" by moving the shift lever to the right and back. |
ChrisFoley |
Jun 27 2017, 06:13 AM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Lo-Fi Version | Time is now: 29th May 2024 - 09:43 AM |
