Where does this part go?, From the dapo files |
ChrisFoley |
Jun 26 2017, 01:54 PM
I am Tangerine Racing Group: Members Posts: 7,920 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
This came off an engine while the car was on our lift
Any thoughts? |
gms |
Jun 26 2017, 01:56 PM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Is it a 4 cylinder with an air pump? there is a rubber piece I have seen that attaches to the fan hub
gms |
Jun 26 2017, 01:57 PM
like this
ChrisFoley |
Jun 26 2017, 03:29 PM
like this Thanks for playing. (IMG:style_emoticons/default/biggrin.gif) Who's next? I'll add a hint. It's definitely aftermarket. |
Krieger |
Jun 26 2017, 04:35 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Obviously belongs in a museum of modern art. Some people pay big money for those! (IMG:style_emoticons/default/biggrin.gif)
IronHillRestorations |
Jun 26 2017, 05:47 PM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
It's part of a weather seal
ChrisFoley |
Jun 26 2017, 06:10 PM
Steve |
Jun 26 2017, 06:25 PM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Home Depot foam in a can to fill a hole?
JeffBowlsby |
Jun 26 2017, 06:27 PM
914 Wiring Harnesses Group: Members Posts: 8,486 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Looks like it may be a piece of the factory goo at the mitered corners of the engine tin perimeter rubber gasket at the tin-engine shelf. AKA "bituminous rope caulk"
yellow75 |
Jun 26 2017, 06:40 PM
Member Group: Members Posts: 88 Joined: 1-October 16 From: pittsburgh Member No.: 20,452 Region Association: None |
engine booger.
rgalla9146 |
Jun 26 2017, 06:52 PM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Was it visible/accessible only when on the lift ?
ChrisFoley |
Jun 26 2017, 09:33 PM
Frankvw |
Jun 26 2017, 10:40 PM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
A protective cap on a live wire ? Like the ones you see on modern cars protecting/hiding the battery + side where wire meets terminal ?
(But then of course melted turning it into carbonlike hardness) |
Spoke |
Jun 27 2017, 04:52 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I saw this on TV on the infomercial with that guy Phil who cuts the boat in half then tapes it back together. It's a new product to improve compression and stop leaks on old engines. You can put it on the outside of the engine where there's a leak of any type.
Or you can put it in the intake to get sucked into the combustion chamber to seal rings. Once in the cylinder, it rummages around inside like a person chewing dentyne gum to clean your teeth. Putting it in the intake may take longer to get into the combustion chamber so the quick way is to remove a spark plug and insert it directly into the combustion chamber with a chopstick. |
Porschef |
Jun 27 2017, 05:40 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
BillC |
Jun 27 2017, 06:41 AM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Where does it go?
In the trash. (IMG:style_emoticons/default/av-943.gif) I guess the bigger questions are: where did it come from and what was it supposed to do? |
ChrisFoley |
Jun 27 2017, 07:10 AM
Where does it go? In the trash. (IMG:style_emoticons/default/av-943.gif) I guess the bigger questions are: where did it come from and what was it supposed to do? Yes, you are absolutely correct. Although Spoke's answer was very close. The Dapo may have gotten the idea from watching an infomercial. |
ChrisFoley |
Jun 27 2017, 07:16 AM
ChrisFoley |
Jun 27 2017, 07:19 AM
rgalla9146 |
Jun 27 2017, 08:18 AM
To 'repair' a crack (and oil leak !) in the block due to a overtightened sump plate.
Lo-Fi Version | Time is now: 2nd May 2024 - 11:47 PM |
