Where does this part go?, From the dapo files |
ChrisFoley |
Jun 26 2017, 01:54 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
This came off an engine while the car was on our lift
Any thoughts? |
Spoke |
Jun 27 2017, 04:52 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I saw this on TV on the infomercial with that guy Phil who cuts the boat in half then tapes it back together. It's a new product to improve compression and stop leaks on old engines. You can put it on the outside of the engine where there's a leak of any type.
Or you can put it in the intake to get sucked into the combustion chamber to seal rings. Once in the cylinder, it rummages around inside like a person chewing dentyne gum to clean your teeth. Putting it in the intake may take longer to get into the combustion chamber so the quick way is to remove a spark plug and insert it directly into the combustion chamber with a chopstick. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:46 PM |
