Where does this part go?, From the dapo files |
ChrisFoley |
Jun 26 2017, 01:54 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
This came off an engine while the car was on our lift
Any thoughts? |
rgalla9146 |
Jun 27 2017, 08:18 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
To 'repair' a crack (and oil leak !) in the block due to a overtightened sump plate.
ChrisFoley |
Jun 27 2017, 08:27 AM
To 'repair' a crack (and oil leak !) in the block due to a overtightened sump plate. That's not the center stud. More likely the case was bolted up with the cam bearing out of position, but even that's hard to believe. The visible crack is horizontal, oil comes out at a steady rate, along the center of the bearing saddle. I measured another case. The saddle is 3/8" thick there. Now the $5000 question. Can it be repaired satisfactorily without a full teardown? Or should I just tell the new owner the engine is junk? |
Lo-Fi Version | Time is now: 17th May 2024 - 03:05 PM |
