Where does this part go?, From the dapo files |
ChrisFoley |
Jun 26 2017, 01:54 PM
I am Tangerine Racing Group: Members Posts: 7,927 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
This came off an engine while the car was on our lift
Any thoughts? |
rgalla9146 |
Jun 27 2017, 08:18 AM
Advanced Member Group: Members Posts: 4,559 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
To 'repair' a crack (and oil leak !) in the block due to a overtightened sump plate.
ChrisFoley |
Jun 27 2017, 08:27 AM
To 'repair' a crack (and oil leak !) in the block due to a overtightened sump plate. That's not the center stud. More likely the case was bolted up with the cam bearing out of position, but even that's hard to believe. The visible crack is horizontal, oil comes out at a steady rate, along the center of the bearing saddle. I measured another case. The saddle is 3/8" thick there. Now the $5000 question. Can it be repaired satisfactorily without a full teardown? Or should I just tell the new owner the engine is junk? |
Valy |
Jun 27 2017, 08:34 AM
Senior Member Group: Members Posts: 1,676 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
To 'repair' a crack (and oil leak !) in the block due to a overtightened sump plate. That's not the center stud. More likely the case was bolted up with the cam bearing out of position, but even that's hard to believe. The visible crack is horizontal, oil comes out at a steady rate, along the center of the bearing saddle. I measured another case. The saddle is 3/8" thick there. Now the $5000 question. Can it be repaired satisfactorily without a full teardown? Or should I just tell the new owner the engine is junk? Just ask the owner if he has more of that magic black glue and move on... (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 03:28 PM |
