Where does this part go?, From the dapo files |
ChrisFoley |
Jun 26 2017, 01:54 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
This came off an engine while the car was on our lift
Any thoughts? |
McMark |
Jun 27 2017, 11:03 AM
QUOTE More likely the case was bolted up with the cam bearing out of position, but even that's hard to believe. Not really. The flange bearing is a tight fit into the camshaft and if the crank turns slightly while assembling the case halves it can cause the two cam bearings to overlap. I'm extremely diligent about this when I put case halves together and I've caught it trying to do this multiple times. But if that's what happened, the case is trash. No cost effective fix. And nothing you can do without disassembly that would be reliable in the long run. Plus if it was the cam bearings, then those bearings are TOAST as well. Nothing about that says salvageable. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:52 PM |
