75 still running rich, 75 still running rich |
brooks944 |
Jun 26 2017, 02:19 PM
Member Group: Members Posts: 241 Joined: 5-September 10 From: Kingston, TN Member No.: 12,139 Region Association: South East States |
My 75 is running rich and fouling plugs after just a few miles. One of the members spent several hours helping me check and figure out the FI a couple of years ago and that made a difference (both on the car and how much I value your experts here). I have 2 extra 'brains' is it time to change that and check? One is from a '75 and one from a 74, does that matter? Both are for a 1.8 which my car is. Fuel injectors are rebuilt as well as the cold start valve. Most vacuum hoses changed. Thanks for any input.
Rick |
brooks944 |
Jun 29 2017, 11:36 AM
OK, got the HF fuel injector kit and measured pin 13 to battery negative after warming the car up. The fuel pressure was about 32 psi, but bouncing from 30 to 40. At higher rpm (3k plus), steadied at 32 psi. After the car warmed up I measured pin 13 to negative battery post and it read 67 ohms and was increasing as the car cooled. is it the CHT sensor? Appreciate everyone's help.
Rick |
malcolm2 |
Jun 29 2017, 11:44 AM
OK, got the HF fuel injector kit and measured pin 13 to battery negative after warming the car up. The fuel pressure was about 32 psi, but bouncing from 30 to 40. At higher rpm (3k plus), steadied at 32 psi. After the car warmed up I measured pin 13 to negative battery post and it read 67 ohms and was increasing as the car cooled. is it the CHT sensor? Appreciate everyone's help. Rick Man, you are on it. I meant to post a pic of my fuel pressure set up. You might want to find a way to have the gauge on there all the time. Sensor seems good. Check out the chart. at 67 ohms your cylinder head must have been over 300*f. you got 1300-ish ohms at 75*F. That is what you should expect. Pressure seems right too. Mine jumps around too. I am in the same range 30-40. You said it felt smoother, have you driven any? still smooth? Maybe you can pull a plug and check the electrode, post a picture. Hey, what about that ECU question? You did or did not swap one out? Are you sure the 75 spare ECU is mounted and not the 74? BTW, here is my FP gauge DIY permanent installation. http://www.914world.com/bbs2/index.php?s=&...t&p=2437471 |
Lo-Fi Version | Time is now: 23rd May 2024 - 09:45 PM |
