Weber IDF Jetting |
Weber IDF Jetting |
FastFroggy |
Jun 30 2017, 12:20 PM
Newbie Group: Members Posts: 47 Joined: 27-November 15 From: Ann Arbor MI Member No.: 19,415 Region Association: Upper MidWest |
I am starting to play around with tuning and plan to start getting some small increments in jetting. Just to see if I can improve drivability for now. I have twin 44s
Simple question for now: I need 4 turns of idle mixture to now stumble off the line. Should I consider jetting richer? thanks |
FastFroggy |
Aug 8 2017, 07:30 PM
Thanks for all your input. Sorry, got delayed by another issue.
Getting back to the set up. This is the hard part. I bought the car with no build documentation out of Billings Montana. Sounds like it has a cam in it and is not a stock 1.7l but besides that I have very basic info. a 1.7l block / car b race header w/ supertrap muffler although I do try the megaphone once and a while. c MSD 6AL with MSD coil d twin Weber Carbs seems relatively mild Carb Spec 44mm Main Jet F-11 / 175 / 135 Venturi 36-4.5 Pump Jet 50EW Idle Jet 50 Issue I am working on: a. only drivability issue is backfiring off throttle. b. looking for improved performance c. preparing for a track day in Sept. I know its limited info, appreciate any guidance. |
Lo-Fi Version | Time is now: 13th May 2024 - 11:35 PM |
