Weber IDF Jetting |
Weber IDF Jetting |
FastFroggy |
Jun 30 2017, 12:20 PM
Newbie Group: Members Posts: 47 Joined: 27-November 15 From: Ann Arbor MI Member No.: 19,415 Region Association: Upper MidWest |
I am starting to play around with tuning and plan to start getting some small increments in jetting. Just to see if I can improve drivability for now. I have twin 44s
Simple question for now: I need 4 turns of idle mixture to now stumble off the line. Should I consider jetting richer? thanks |
ChrisFoley |
Aug 15 2017, 07:05 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Keep the 44s. Don't expect good performance below 4500 rpm. Anything you do to make the engine work better down low will only hurt the top end.
I run 40s because of SCCA rules but I use 36mm venturis and made a lot of mods to the carbs to improve flow at WOT. |
Lo-Fi Version | Time is now: 14th May 2024 - 07:11 AM |
