Won't start! Will start if I coast down hill and pop clutch! |
Ian Stott |
Jul 1 2017, 05:18 AM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
As described! What is up with this situation? Engine runs beautiful when warmed up, will restart no problem if It has been shut off for even a few hours. Kudos to the battery and starter as I have tried to start it normally when it has been sitting for a few days, won't catch, thank goodness I live on a hill, coast down the hill a bit, put her in 3rd gear pop the clutch and vrooom! Have done this 6 times now!
Ian Stott Moncton Canada |
Spoke |
Jul 3 2017, 09:03 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
So it doesn't start when cold but will start if you push/coast start it?
What are the differences in both methods? Engine speed: Starter: slow Coast: slow Ok, so engine speed should not be the issue. Extra fuel when cranking: Starter: YES, the ECU extends the injector pulses to put in more fuel when cranking. Coast: NO, the ECU sets injector pulse width by temp of engine/ambient/CHT Here's a difference, pulse width during cranking may be flooding the engine. Maybe not. Does the engine run rich? Have you had the AFR checked? Voltage at coil: Starter: Voltage at coil will be lowered by IR drops in the wiring applying less voltage at the coil. Coast: Voltage should be close to battery voltage since starter is not cranking. Check the voltage at the coil with a voltmeter when cranking. Measure from coil + wire to engine case ground, not the battery ground. Also, pull a plug wire and install a spare plug on the wire and ground the plug and look for spark when cranking. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:37 PM |
