clutch problems - SOLVED, grabby and notchy |
mzalanka |
Jul 1 2017, 11:44 AM
Member Group: Members Posts: 116 Joined: 11-July 11 From: Portland, OR Member No.: 13,300 Region Association: None |
I'm reposting my question from yesterday, which was poorly received. In hindsight I should have just asked the question and skipped the degree of detail and lame attempts at humor. Wish delete was an option.
Two clutch-related problems: clutch pedal feel that gets "notchy" or, for lack of a better term, "not smooth" as the engine warms, and also judder or grabbing from take-off in first (also gets worse as engine warms). I do not know my way around a clutch or a transmission. The one installed was put in by the engine rebuilder and sat for 5 years. Vehicle has new pressure plate, friction disk, TOB, Gemo cable, rebuilt pedal cluster. Just fixed an input shaft leak, drove about 100 miles on it. Seems like that could explain the grabbing but not the worsening notchiness, which is still present even when engine is off, warm, and has been present since Mile 0. I've ordered a clutch kit from PP and will probably just replace the whole thing, but what specifically should I be looking for in terms of faults? Thanks. Long time lurker but rare poster. Greatly appreciate the World. |
mzalanka |
Jul 20 2017, 08:31 AM
Found two problems when I dropped the trans.
1) Pivot ball under shimmed for resurfaced flywheel. Also, pivot ball was heavily worn (prior fork pivot ball bushing was toast, so metal on metal for some time). Sourced an OEM part (took some time), shimmed with 2 washers, which restored proper fork geometry. 2) Moderately fouled friction disk. Also not a Sachs disk - clearly much less robust than the replacement. Pulling away from stop lights smoothly and without any unpleasantness, at least in the past 10 miles. Thanks again to the World for all the help and the welcome opinions! (IMG:style_emoticons/default/first.gif) |
mzalanka |
Jul 20 2017, 08:33 AM
Moral of the story is that even seemingly small trans input shaft leaks can mess up the clutch.
Lo-Fi Version | Time is now: 20th May 2024 - 10:02 PM |
