| mskala |
Jul 3 2017, 02:26 PM
R ![]() ![]() ![]() Group: Members Posts: 1,944 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
My e-brake gauge light was always on. Somewhere in the wire there is a short,
it's not the switch under the handle. The wire seems to go down the left long toward the firewall, but then where is it going physically? For now it's disconnected but I'd like to try to find the short sometime. Thanks |
| McMark |
Jul 3 2017, 02:45 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Yes, along the left long toward the firewall, then crosses at the firewall to the center tunnel (originally behind the backpad). From the center tunnel it joins the rest of the wire loom running up to the dash area.
| mskala |
Jul 4 2017, 07:50 AM
hmm maybe I'll wait until winter unless I need to get the backpad out for other
reasons. Thanks |
| Krieger |
Jul 4 2017, 08:18 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,855 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Check your switch on the master cylinder. It may need to be reset.
| McMark |
Jul 4 2017, 09:50 AM
Check your switch on the master cylinder. It may need to be reset. If you have a 19mm master cylinder. Original 17mm MC have two wire connections and no switch. But, that's a great thought Andy. The flashing light has two possible meanings: 1) eBrake is on 2) brake pressure is (or has been) unequal between the front and rear brake circuits. |
Lo-Fi Version | Time is now: 2nd May 2026 - 06:14 AM |
