Engine oil leaking from bell housing AGAIN!, What am I doing wrong? |
zymurgist |
Jul 20 2005, 02:36 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Thanks for the tips, Marty. I have used a sleeve on my Corvette front main seal, since I was too cheap to replace a damper that had only about 5K miles on it. I will check on the condition of the sealing surface on the flywheel... I know for a fact that there are no grooves that can catch a fingernail, but I'm not sure whether there is any pitting. I didn't realize that sleeving was an option for this part.
3d914 |
Jul 20 2005, 05:28 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
An alternative to a sleeve, is to check the width of the wear on flywheel. I had good luck pressing the seal in an extra 2mm or so - allowing the seal to wear on a fresh area of the flywheel.
Not a long-term fix, but it worked. Enjoy! |
zymurgist |
Jul 21 2005, 05:19 AM
I looked at the flywheel again last night. There are two noticeable wear areas where it rides against the seal. I've been referred to Peak Performance VW in Seabrook, MD. I'm going to take the flywheel to them and see whether they recommend sleeving or polishing.
zymurgist |
Jul 21 2005, 05:31 AM
My orange seal. I took about 6 pictures and this was the only one that came out in focus. It's made by Victor Reinz, and the box had a label that reads "Made in Germany."
tat2dphreak |
Jul 21 2005, 12:22 PM
HPH DOES do mail order, I just got a brown seal from pelican too though... made be elring or something like that, says made in germany too.. I don't think mine was leaking until I pulled the engine and checked the free-end play... that shouldn't have F'd it up though... |
Jake Raby |
Jul 21 2005, 12:36 PM
The Viton seal is all I use and stock, but about 25% of them have too small of an OD creating fitting issues, as a leak can come from around the seal... We measure them and send the junk back.
Flywheels that have grooved surfaces eat seals for breakfast. |
zymurgist |
Jul 21 2005, 12:45 PM
Jake,
1. How would you define "grooved?" If you can feel it with your fingernail, no matter how slight, it's a groove? There are no less than 2 of these smooth but very very slight indentations on the flywheel that came out of Babydoll. (I don't know what the other one looks like, but I can get it out of my garage attic and inspect it thoroughly.) Would a flywheel with such a grooved surface then be a candidate for sleeving, assuming that it is in otherwise good shape? 2. I'm pretty sure that my orange seal says Viton on it. |
Lo-Fi Version | Time is now: 28th May 2024 - 06:36 PM |
