| db9146 |
Jul 4 2017, 08:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None
I am converting from a tail shifter to a side shifter. I have one but its history is unknown to me - it came out of a parts car that I've had for 10 years or so and it had been sitting in a dead car for unknown years before that. I've never rebuilt one so I approached a local expert about rebuilding it prior to putting it in the car but he recommenced that I stick it in and run it to get an idea of its condition before I spend any time or money on it. Not a bad plan just not what I had in mind.
I have cleaned it up and built a bracket to hold the accelerator linkage pivot shaft but after filling it with fresh oil, I've noticed that its leaking from the driver's side output shaft. Can the seal on this side be replaced easily? |
| SirAndy |
Jul 4 2017, 09:02 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,458 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Yes, output shaft seals are pretty straight forward to replace. Just drain the oil, remove the shaft and replace the seal.
I don't remember the torque setting on the shaft nut, but it is pretty low ... (IMG:style_emoticons/default/smash.gif) |
| bdstone914 |
Jul 4 2017, 09:42 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Do you have all of the other parts needed to make the conversion to the side shift Trans? If you dont have them i have most if not all of them. And you have 6 in it?
| Spoke |
Jul 4 2017, 10:24 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,351 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
I have one but its history is unknown to me With this limited info, the transmission could be functioning perfectly or impossible to get into first without grinding. The sycnros are the most common issue with 901 transmissions. If the transmission isn't in the car, I assume you've spun the input shaft and shifted and all felt fine? I think Dr Evil has a video of how to rebuild the transmission if you're interested in that. He did mine before I installed it and it was a good thing. The intermediate bearing was toast. |
| wndsrfr |
Jul 5 2017, 04:27 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,460 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region
Yes, output shaft seals are pretty straight forward to replace. Just drain the oil, remove the shaft and replace the seal. I don't remember the torque setting on the shaft nut, but it is pretty low ... (IMG:style_emoticons/default/smash.gif) Torque is 18 ft/lbs....according to Dr. E. |
| dlee6204 |
Jul 5 2017, 05:43 AM
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
IMO you need to replace ALL the seals on the box otherwise you'll likely have more leaks in a short amount of time. Input seal, shift console seals, speedo seals, axle output seals. If the box turns out good,it would save you some headache.
| jkb944t |
Jul 5 2017, 05:50 AM
Member ![]() ![]() Group: Members Posts: 470 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
IMO you need to replace ALL the seals on the box otherwise you'll likely have more leaks in a short amount of time. Input seal, shift console seals, speedo seals, axle output seals. If the box turns out good,it would save you some headache. (IMG:style_emoticons/default/agree.gif) It is so easy and not expensive to change the seals while it is out of the car and as mentioned it is likely that other seals will start leaking shortly. Jeff B |
| Mikey914 |
Jul 5 2017, 11:05 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Fix whats leaking now, keep an eye on it and take it out over the winter to service the entire unit. Don't loose valuable drive time now unless you have to. (IMG:style_emoticons/default/biggrin.gif)
| wndsrfr |
Jul 5 2017, 07:49 PM
Fix whats leaking now, keep an eye on it and take it out over the winter to service the entire unit. Don't loose valuable drive time now unless you have to. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/agree.gif) It's easy to do that output flange seal with the engine & trans in the car..... |
| Dr Evil |
Jul 13 2017, 10:35 AM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
One thing to consider, and is common, especially in a box that sat, is that the output flange shaft is pitted and a new seal will not fix this. I have good flanges if you find you need one. Seals, too. All parts, really. Yes, still have DVDs for sale (IMG:style_emoticons/default/smile.gif)
I would pull the flanges from the spare box, check the sealing surface, and replace the leaky side flange if indicated. Do both output seals and input shaft seal as its cheap and easy to do while you are there. |
Lo-Fi Version | Time is now: 12th March 2026 - 06:58 PM |
