wilchek |
Senior Member ![]() ![]() ![]() Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 ![]() |
I am trying to build a home generator off of a VW bug generator and a exercise bike. Ride the bike---see the light turn on, for a sciene project for kids. Does anyone know if the generator of VW bugs had "permanent magnets" or do I need to hook up a battery to the generator to develope a field current (energize the magnets). Any help would be great. Any other suggestions would help as well. I am at the trial and error part.
scotty914 |
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,528 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 ![]() |
yes it needs out side current for the exciter which must be connected through a resistor or bulb to ground ( IIRC) . when you apply the source power the light will come on once you start making power the light will go off.
you might do better making a generator out a small electric motor with permanate magnets |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
what the hell is that good for? so the generator needs power to produce power??? isn't that counter-productive?
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
You generate electricity by moving coils of wire through a magnetic field. Both alternators and generators use an electromagnet to generate the manetic field, because you can control the output by varying that field. The energy required to make the field is much less than the output, so it is only slightly counter productive. The down side is if you have no electricity to get it started, it won't generate anything. |
wilchek |
Thanks Scott, that is what I thought
kind of, it will produce more than the battery puts out. It will produce some power without the battery hooked up. It is generally not strong enough without being an electromagnet. Your car alternator will not work without a battery. However, there are some generators/alternators that have what is called permanent magents that do not require external batteries but have less output (noramally power window motors have permanent magents). Bottom line, spin the gen/alt faster or add more magentics = more power. Actually most voltage regulators work by adjusting power to the magnets, creating the proper amount of supply out of the alternator of around 13.5 volts. |
Lo-Fi Version | Time is now: 1st July 2025 - 02:00 AM |
