73 2.0 running *really* rich |
rpc |
Jul 7 2017, 03:14 PM
Member Group: Members Posts: 50 Joined: 18-May 11 From: Reston, VA Member No.: 13,084 Region Association: MidAtlantic Region |
History: We bought this '73 2.0 last summer. It ran ok at the time, though on cold start-up it would choke if we gave it throttle before it had a chance to warm up for a few minutes. We dropped the drivetrain in the fall to do a bunch of general cleanup on the engine and trans, including:
Today: We finally got everything back together and started the car but it was running really rich, so much so that we could barely keep it running. After we shut it off it wouldn't start again. It would spin fine, but not even a hint of firing. Things we've done:
So first, I think it's so badly flooded that we need to wait a day and/or pull the plugs so that the cylinders dry out. Second, I'm guessing that replacing the hoses fixed a bunch of air leaks, which some PO had compensated for by richening the mixture. I could very well be wrong, just a guess. I've read a good amount and have a basic understanding of the D-jet system, but I'm looking for pointers about where I should start in fixing this. If I'm right about the flooding we should be able to get it started. Then what do we need to start checking to address the rich running? |
BeatNavy |
Jul 7 2017, 06:39 PM
That CHT number doesn't seem out of whack in general. Definitely need to make sure you have good continuity from the lead to the ECU - a lot of times these wires get brittle and kink and crack. The wire may look ok but still have a break.
I have a spare MPS that holds a vacuum and is tuned to 2.0 specs if you need a quick swap (also have a spare CHT if you want to try that). You could eliminate the CSV as the cause just by pulling that fuel line and plugging the fuel rail. Lastly, it's pretty easy to verify fuel pressure and make sure that hasn't spiked for some reason. Otherwise, I think you are on the right track. |
Lo-Fi Version | Time is now: 20th May 2024 - 01:21 AM |
