73 2.0 running *really* rich |
rpc |
Jul 7 2017, 03:14 PM
Member Group: Members Posts: 50 Joined: 18-May 11 From: Reston, VA Member No.: 13,084 Region Association: MidAtlantic Region |
History: We bought this '73 2.0 last summer. It ran ok at the time, though on cold start-up it would choke if we gave it throttle before it had a chance to warm up for a few minutes. We dropped the drivetrain in the fall to do a bunch of general cleanup on the engine and trans, including:
Today: We finally got everything back together and started the car but it was running really rich, so much so that we could barely keep it running. After we shut it off it wouldn't start again. It would spin fine, but not even a hint of firing. Things we've done:
So first, I think it's so badly flooded that we need to wait a day and/or pull the plugs so that the cylinders dry out. Second, I'm guessing that replacing the hoses fixed a bunch of air leaks, which some PO had compensated for by richening the mixture. I could very well be wrong, just a guess. I've read a good amount and have a basic understanding of the D-jet system, but I'm looking for pointers about where I should start in fixing this. If I'm right about the flooding we should be able to get it started. Then what do we need to start checking to address the rich running? |
rpc |
Jul 9 2017, 04:27 PM
My buddy checked the MPS vacuum today and found: "It does not hold suction. When vacuumed to 20 " Hg it dropped to 15 in 5 seconds and continued to go down. I put hose clamps on both ends of the hose to check again--same result."
Sounds like the MPS has a terminal vacuum leak. Unless I've read everything wrong, this explains the rich running (though we'll continue to check other things). What's the best solution for the MPS, have it repaired or try to find a good replacement? If repair, who's recommended? The MPS is part #0 280 100 043. |
Lo-Fi Version | Time is now: 20th May 2024 - 12:41 AM |
