| 80cap |
Jul 8 2017, 09:23 AM
Member ![]() ![]() Group: Members Posts: 322 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
What is the recommendation for the first oil change? I have 50 miles on a new engine. Did the cam break in out of the car.
Brian |
| Mark Henry |
Jul 8 2017, 01:40 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Depends on the oil used, I'd do it now.
If you plan to run synthetic stick with dino for the first few changes. Most only like dino in the aircooleds. |
| 80cap |
Jul 8 2017, 03:35 PM
Brad Pen break in oil.
Brian |
| porschetub |
Jul 8 2017, 05:15 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,954 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Brad Pen break in oil. Brian Do it now as already mentioned in fact you should really do it sooner,Mark is correct about oil,seen oil leak issues with synthetic oil ,RMS seal and pushrod tube seals come to mind,when these motors were designed they used dino oil ...nothing changed. I don't use running in oil just run the same oil from day one. Hope its running well (IMG:style_emoticons/default/beerchug.gif) . |
| McMark |
Jul 9 2017, 06:25 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
If this is the same oil used during cam break-in then it's absolutely time to change it. If you already changed the oil once, go a bit longer on this batch.
| Mark Henry |
Jul 9 2017, 06:32 AM
The BP oil is only used for breaking in the cam and rings, time to switch to your regular oil.
What oil is very subjective and personal opinion, I use Chevron Delo 15w40, good dino oil, fairly cheap, about the same as the old shell Rotilla T. Being cheap means I change it more often, which is a good thing. I also run it in my farm tractor so I buy it by the pail. Can be a bit harder to find here, it's a diesel oil so most bulk and truck places have it. |
| McMark |
Jul 9 2017, 06:36 AM
I thought they pulled the zinc from Delo...
| 80cap |
Jul 9 2017, 06:55 AM
Thanks!
I'll change it today. Brian |
| Mark Henry |
Jul 9 2017, 07:11 AM
I thought they pulled the zinc from Delo... I think you're thinking of Rotilla T, last info I had on Delo was: 15W40 CHEVRON DELO 400LE Diesel Oil, conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM, = 73,520 psi zinc = 1519 ppm phos = 1139 ppm ZDDP = 1300 ppm I do know the lighter grades of Delo have a lot less zinc. Now I'll have to check because the last time I bought Delo was about 4 years ago, I bought a whole skid of pails. My tractor engine and trans oil change (same oil) is over 2 pails (40+ quarts/liters). I'm down to my last pail so I'll ask for the spec when I go to order. |
| Mark Henry |
Jul 9 2017, 07:22 AM
I thought they pulled the zinc from Delo... On Chevron Delo 400 LE 15w40 they list zinc as .13% mass which is 1300ppm, still good. But I'm correct, the lighter grades of Delo do have less zinc, as low as 760ppm https://cglapps.chevron.com/msdspds/PDSDeta...p;docFormat=PDF http://www.chevronlubricants.com/en_US/pro...ml#.WWIv_oQrJhF |
Lo-Fi Version | Time is now: 7th November 2025 - 03:28 AM |
