best location to mount fire extinguisher, looking for ideas... |
914 RZ-1 |
Jul 13 2017, 11:12 AM
Porsche Padawan Group: Members Posts: 682 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
Where is the best place to mount a small fire extinguisher? In the cabin? In the front or rear trunk?
I've kept it behind the passenger seat, but if someone tall wants to sit there, they won't be able to move the seat back. |
Alphaogre |
Jul 13 2017, 11:23 AM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
I drilled a couple holes through the lateral boxed section and mounted on against it so it will be under the passenger in a space they don't use and is easily reachable when I am driving alone.
It would depend if you want it visible or not... |
jfort |
Jul 13 2017, 11:53 AM
Senior Member Group: Members Posts: 1,134 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
I mounted it on the sill/floor beside my left leg so I can reach it quickly with my left hand. it's forward enough for the seat to slide forward enough
Marv's3.6six |
Jul 13 2017, 12:17 PM
Actual member 7" Group: Members Posts: 695 Joined: 22-November 04 From: Huntington Beach, Ca. Member No.: 3,165 Region Association: Southern California |
I chose under the dash board. It is up and out of the way, may not look like it is out of the way but it is up behind the radio location, does not interfere with anything and yet still in plain site..... is released with a pull pin. Easy peasy.
Attached thumbnail(s) |
toolguy |
Jul 13 2017, 12:35 PM
+1 for in front of the passenger seat. .
It's out of the way and the easiest to access. . I don't want to be trying to open the either trunk if the engines on fire. . mere seconds can be essential in an emergency and the difference between failure and success. . |
IronHillRestorations |
Jul 13 2017, 12:41 PM
+2 on passenger side floor
Ed_Turbo |
Jul 13 2017, 12:45 PM
Member Group: Members Posts: 440 Joined: 5-June 17 From: Hacienda Heights, Ca. Member No.: 21,151 Region Association: Southern California |
I drilled a couple holes through the lateral boxed section and mounted on against it so it will be under the passenger in a space they don't use and is easily reachable when I am driving alone. It would depend if you want it visible or not... (IMG:style_emoticons/default/agree.gif) Ask yourself if you want to have it visible or hidden then go from there. What you want is having it as close as possble to quickly take out the fire like rotisserie man toolguy said. It can be pricey for older cars to replace electric stuff. |
Mr Pharmacist |
Jul 13 2017, 01:13 PM
Member Group: Members Posts: 69 Joined: 15-September 09 From: United Kingdom Member No.: 10,807 Region Association: England |
Mines in on the central tunnel between driver and passenger.
here's a pic from when i had my seats out: (IMG:http://www.914world.com/bbs2/uploads_offsite/i226.photobucket.com-10807-1499973204.1.jpg) |
Cracker |
Jul 13 2017, 03:09 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Racer |
Jul 13 2017, 04:01 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
I've had them
1) Behind the driver's seat 2) in front of passenger seat, on the floor (like Alphaogre) 3) in front of gear lever, to the right of the gas pedal (where a console might be on some cars) - like the white bottle above |
oakdalecurtis |
Jul 13 2017, 04:04 PM
Oakdalecurtis Group: Members Posts: 1,322 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Where is the best place to mount a small fire extinguisher? In the cabin? In the front or rear trunk? I've kept it behind the passenger seat, but if someone tall wants to sit there, they won't be able to move the seat back. Oakdalecurtis ** Group: Members Posts: 444 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California Hi Brian, this is a repost of a product I found recently that you may want to consider: I purchased the 6 foot BlazeCut Fire Suppression System. This length only requires one length down one side of the lid, one curve, and one length back the other side of the lid. I also found that the stiff tubing does not like to bend into a tight enough arc to fit into the confines of the engine lid. The tube kinked at the center of the curve, but I don't think it damaged it. I bought an electrical gray pipe curve, 3/4" ID, split it with my band saw, and zip tied and taped it around the BlazeCut tubing at the center of the arc where the tubing wanted to kink. This supported and held the tubing, keeping the tubing in the required arc while preventing it from kinking. I also found that plastic zip ties were not strong enough to hold the tubing in position under the engine lid. The stiff BlazeCut tubing does not like to bend or go where you want it to very easily. As you can see, I removed my rain tray a while ago since I never take the car out in bad weather and the engine runs cooler without it. I fastened the tubing to the underside of the engine lid using metal pipe claps, 3/4 ID, and short self tapping metal screws into the lid supports. I wrapped the BlazeCut in heavy plumbers tape wherever it came in contact with the metal lid. I also cut thin strips of black tape and put them on the top side of the BlazeCut tube so you could not easily see the white tubing through the engine grill from the outside. If you look on the left side of my engine lid, you can also see a steel braided cable I added a while back so I don't have to hold on to the engine lid when I open it. Without the cable, if you popped the engine lid and didn't hold it, it would fly open and put a lot of bending force on the hinges, which I have already rewelded once. Now the cable catches it before it works on the hinges. BTW, if you have a weak opening engine cover, here's a link to an easy and simple fix that lets you put more pop in the opening, especially with the extra weight of the BlazeCut under the lid. My lids pops open fully now, even with the tubing under it. http://www.914world.com/bbs2/index.php?sho...=290514&hl= I hope I never have to find out how well the BlazeCut tubing works! |
914 RZ-1 |
Jul 21 2017, 02:59 PM
I chose under the dash board. It is up and out of the way, may not look like it is out of the way but it is up behind the radio location, does not interfere with anything and yet still in plain site..... is released with a pull pin. Easy peasy. I was thinking this was a good place: up under the passenger side dashboard. Is it possible to drill holes without puncturing the gas tank? I'd like to use bolts and nuts instead of sheet metal screws. |
Lo-Fi Version | Time is now: 19th April 2024 - 06:42 PM |
