Removing Old Door Fuzzy, HELP |
1adam12 |
Jul 13 2017, 03:26 PM
Member Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California |
Hi everyone! I'm trying to install a new set of outer door fuzzies I recently purchased from 914rubber but I'm having a hell of a time removing the old fuzzy. I was able to locate and remove the 3 screws that hold the original fuzzy in place but it's been difficult trying to get the old decrepit fuzzy strip out of the retaining bracket?
Does this bracket come off somehow because it's a pain trying to pick and break up the old strip through the top of the door. Even if I was able to break up most of the old strip, the top metal portion would still be lodged within the top of the bracket. Attached thumbnail(s) |
1adam12 |
Jul 13 2017, 04:57 PM
I guess my question is does the entire piece of aluminum strip that holds the fuzzy and scraper come off once you've removed the 3 small screws? It doesn't seem like I can pry it off without damaging the track or the door but I'm being cautious.
914_teener |
Jul 13 2017, 05:53 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I guess my question is does the entire piece of aluminum strip that holds the fuzzy and scraper come off once you've removed the 3 small screws? It doesn't seem like I can pry it off without damaging the track or the door but I'm being cautious. Did you actually unscrew the whole screw or did they break off? I had to drill the screws out in my car cause they broke off and couldn.t pull the channel off without effing it up. |
Lo-Fi Version | Time is now: 12th May 2024 - 12:40 PM |
