Removing Old Door Fuzzy, HELP |
1adam12 |
Jul 13 2017, 03:26 PM
Member Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California |
Hi everyone! I'm trying to install a new set of outer door fuzzies I recently purchased from 914rubber but I'm having a hell of a time removing the old fuzzy. I was able to locate and remove the 3 screws that hold the original fuzzy in place but it's been difficult trying to get the old decrepit fuzzy strip out of the retaining bracket?
Does this bracket come off somehow because it's a pain trying to pick and break up the old strip through the top of the door. Even if I was able to break up most of the old strip, the top metal portion would still be lodged within the top of the bracket. Attached thumbnail(s) |
jim_hoyland |
Jul 14 2017, 01:17 PM
Get that VIN ? Group: Members Posts: 9,282 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Does the older fuzzy cause the window to become harder to crank up?
Mikey914 |
Jul 17 2017, 11:42 PM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Does the older fuzzy cause the window to become harder to crank up? Should (if any change) make easier as it's now riding on the new fuzzey. There is positive contact, but the largest issue cranking down with the late type seals. The early ones are the original design. I even use them on my 75. Attached image(s) |
Lo-Fi Version | Time is now: 12th May 2024 - 07:21 AM |
