1974 2.0 Resurrection, Project Thread |
Dck356 |
Jul 15 2017, 06:46 AM
Newbie Group: Members Posts: 20 Joined: 9-April 12 From: Davidson, NC Member No.: 14,355 Region Association: South East States |
Good morning. I’m new to the forum and thought I should introduce myself and start a project thread. I’ve been away from the air-cooled world for a while - I’ve had several 356s and 911s and am super excited to get this 914 back on the road.
The car is a 1974 2.0 and is in ok shape. Standard amount of rust, but the hell holes appear to be in pretty good shape. The PO bought it from a member in California and I don’t think was ever able to get it running well. When I bought the car a year ago it had been sitting for a good 12 years. The car popped up in the classifieds late one Saturday night just about 45 minutes south of me. It was priced right, plus the car was wearing a decent set of fuchs. My wife and I hopped in the car Sunday morning and brought it home. (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122803.1.jpg) Here are some pics showing where I am to date. Toward the end of the the thread I’ve added pics outlining the process I’ve been following to try and get the timing dialed in. I’m afraid I need some help here from the group! So on to the pics: Got it pulled off the trailer, power washed as much of the nastiness off as I could and tucked it away in the garage until the first batch of parts arrived. (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122803.2.jpg) First order of business was to sort out the fuel system. Pulled the tank and found a bunch of nasty surface rust… not to mention a small development of mice condos and all the disgusting things that come along with them. Yuck. (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122803.3.jpg) Lots of grinding and sanding… (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122803.4.jpg) Taping and priming… (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122804.5.jpg) And finally… ordered some L13K color-matched paint. It actually matched pretty well. (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122804.6.jpg) I did a ton of prep work and am really happy with how it turned out. (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122804.7.jpg) The tank had rust and crud inside, plus a pretty good size hole on the backside where it had been sitting on one of the felt pads in the front trunk. So, off to the radiator shop for a little welding, sealing, and then back home for paint. At this point I had installed all new fuel lines in the engine bay and SS lines from Tangerine in the tunnel. Also decided to go ahead and have some of the bits plated. Things just looked too nice to got back with nasty hardware. (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122804.8.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122804.9.jpg) Got everything hooked up to the tank, added some gas… and the fuel pump promptly decided to quit. So, ordered new pump, moved it to the back of the firewall and hooked everything up. (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122805.10.jpg) So this brings us to current day and the issue at hand. Here’s the challenge for the group: when I try and set the timing to 27 degrees, the rpms jump up to 3k - I tried to adjust the idle, but the idle screw is turned all the way in. So, I wanted to outline the steps I’ve taken to see if I’ve made any mistakes. Here we go… Step 1: jacked up rear wheel and put car in 5th gear (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122805.11.jpg) Step 2: grabbed my handy TDC tool that indicates compression stroke. Put it into Cylinder #1 and turned the rear wheel until I heard the whistle. (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122805.12.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122805.13.jpg) Step 3: with the whistle indicating the compression stroke, I continued to turn the wheel until the distributor rotor was pointing at the #1 notch on the distributor housing. (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122805.14.jpg) Step 4: I then checked to make sure that the “0” on the fan was in the correct spot. It’s a little hard to see, but it is right there. (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122806.15.jpg) Step 5: then looked at the notch on the flywheel to make sure it was lined up with the split in the case. And yes, it’s right where it is supposed to be. (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122806.16.jpg) Step 6: So, at this point I’m pretty sure everything is set at TDC. I went ahead and fired the car up. It started immediately at settled right in at 900 rpm. At this point I checked and adjusted the dwell right at 47 degrees: (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122806.17.jpg) Step 7: at this point I hooked up my timing light and looked to see how things were lining up. May be a little tough to see, but with everything set to TDC the “0” setting is actually a little to the left of the “v” in the housing - see the little white dot. Isn’t it supposed to be lined up in the “v”? (IMG:http://www.914world.com/bbs2/uploads_offsite/i773.photobucket.com-14355-1500122806.18.jpg) This is where if I turn the distributor to get to the red line (27 degrees) the rpms go up to 3k. And that is with the idle screw turned all the way in. So what have I done wrong? Pretty positive that I’m at TDC. Am I dealing with a bad distributor or a massive vacuum leak? I’m at a total loss as to where to go from here and would really appreciate some direction. Lastly, I will do my best to keep this thread updated with my progress. I’ve been on several other forums and I must say, I’ve been really impressed with the character of this group. Thanks in advance for everyone’s help and I look forward to jumping in! |
BillC |
Jul 15 2017, 08:54 AM
Senior Member Group: Members Posts: 534 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
When you set the timing, you need to remove the vacuum hoses from the distributor and cap/plug the hoses. If you didn't cap the hoses, you'll get a vacuum leak that will make the engine run faster.
Also, don't forget to unplug and reconnect the hoses when finished. |
Dck356 |
Jul 15 2017, 09:44 AM
When you set the timing, you need to remove the vacuum hoses from the distributor and cap/plug the hoses. If you didn't cap the hoses, you'll get a vacuum leak that will make the engine run faster. Also, don't forget to unplug and reconnect the hoses when finished. There is only one vac line that runs from the throttle body to the distributor. I did disconnect and plug the distributor end of the line. Thanks BillC! |
Jul 15 2017, 02:25 PM
Idle timing is not exactly at TDC. So I wouldn't worry about that.
Dynamic timing is set at 3500 RPM, so that the centrifugal advance is all in. Were you revving the engine up to 3500 to see the 27 deg BTDC mark, or just letting it run at idle? If the latter, your timing would be way way too advanced and you would have a very high idle. If the engine won't drop down to idle RPM after you set the timing at 3500, then the next suspect would be vacuum leaks. --DD |
Dck356 |
Jul 15 2017, 08:15 PM
Thanks Dave. I had one of my girls hold the throttle at 3500 when attempting to get to 27 degrees. Looks like I need to start hunting down the vacuum leak.
Jul 16 2017, 09:37 PM
What, don't you have three hands to do it yourself? (IMG:style_emoticons/default/wink.gif)
You can open the throttle with one hand and hold the timing light with the other. Guess at how far the mark needs to move to line up correctly, then let it drop back to idle and move the distributor enough to move the fan that much in the light. Then rev the motor back up again and re-check. That's a way to do the job with only two hands... --DD |
porschetub |
Jul 16 2017, 09:58 PM
Please get rid of the hose (cutter) screw clamps on the fuel hoses really unsafe....honest.
Looks like a good sound car and you are on the right track,nice work so far,good luck. |
Jul 17 2017, 09:46 AM
I see proper fuel-injection hose clamps, not worm-gear clamps. Am I overlooking something?
--DD |
arne |
Jul 17 2017, 11:04 AM
Serial Rescuer of old vehicles... Group: Members Posts: 731 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
There's a worm gear clamp on the inlet side of the fuel pump. All the other clamps pictured are the good ones.
Montreal914 |
Jul 17 2017, 02:00 PM
Senior Member Group: Members Posts: 1,541 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
What, don't you have three hands to do it yourself? (IMG:style_emoticons/default/wink.gif) You can open the throttle with one hand and hold the timing light with the other. Guess at how far the mark needs to move to line up correctly, then let it drop back to idle and move the distributor enough to move the fan that much in the light. Then rev the motor back up again and re-check. That's a way to do the job with only two hands... --DD I usually remove the return spring on the butterfly, it free's up that hand. Just don't for get to put it back (IMG:style_emoticons/default/rolleyes.gif) |
Dck356 |
Jul 17 2017, 05:39 PM
Please get rid of the hose (cutter) screw clamps on the fuel hoses really unsafe....honest. Looks like a good sound car and you are on the right track,nice work so far,good luck. Yes. That is the only worm drive clamp. Need to order the right size of the non-cutting variety (IMG:style_emoticons/default/smile.gif) . Thanks! |
Dck356 |
Jul 17 2017, 05:43 PM
What, don't you have three hands to do it yourself? (IMG:style_emoticons/default/wink.gif) You can open the throttle with one hand and hold the timing light with the other. Guess at how far the mark needs to move to line up correctly, then let it drop back to idle and move the distributor enough to move the fan that much in the light. Then rev the motor back up again and re-check. That's a way to do the job with only two hands... --DD Thanks Dave! Update: I pulled the throttle body and all the intake. New gaskets and hoses all ordered. Also held the throttle body up to the light and it looks like the butterfly valve is worn - lots of light sneaking through. Got a pretty pricey quote to rebuild - may see if I can find a used one in good shape. Stay tuned... |
LowBridge |
Jul 17 2017, 05:49 PM
Member Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States |
looks like you have a solid runner... good luck with the resurrection (IMG:style_emoticons/default/beerchug.gif)
flmont |
Jul 17 2017, 10:56 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
That TDC tool is pretty neat,..where did U acquire such a tool,..??
Dck356 |
Jul 18 2017, 04:00 PM
ConeDodger |
Jul 18 2017, 04:29 PM
Apex killer! Group: Members Posts: 23,556 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
This will be a fun one to watch! (IMG:style_emoticons/default/evilgrin.gif)
flmont |
Jul 18 2017, 08:36 PM
Cool,...Thanks DcK356
whitetwinturbo |
Jul 18 2017, 10:00 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
Lo-Fi Version | Time is now: 23rd April 2024 - 06:37 AM |
